Analysis of spread spectrum time domain reflectometry for wire fault location, IEEE Sensors Journal, vol.5, issue.6, pp.1469-1478, 2005. ,
DOI : 10.1109/JSEN.2005.858964
A simple and accurate model for wire diagnosis using reflectometry, PIERS Proceedings, 2007. ,
The invisible fray: a critical analysis of the use of reflectometry for fray location, IEEE Sensors Journal, vol.6, issue.3, pp.697-706, 2006. ,
DOI : 10.1109/JSEN.2006.874017
Properties of dielectrics from reflection coefficients in one dimension, 1963. ,
Inversion of the telegraph equation and the synthesis of nonuniform lines, Proceedings of the IEEE, pp.383-392, 1971. ,
DOI : 10.1109/PROC.1971.8179
Inverse Scattering for Discrete Transmission-Line Models, SIAM Review, vol.29, issue.3, pp.359-389, 1987. ,
DOI : 10.1137/1029075
transmission lines, Journal of Mathematical Physics, vol.23, issue.12, pp.2286-2290, 1982. ,
DOI : 10.1063/1.525307
Recovering lossy multiconductor transmission line parameters from impedance or scattering representations, IEEE Transactions on Advanced Packaging, vol.25, issue.2, pp.200-205, 2002. ,
DOI : 10.1109/TADVP.2002.803273
An Inverse Scattering Approach to Soft Fault Diagnosis in Lossy Electric Transmission Lines, IEEE International Symposium on Antennas and Propagation, 2010. ,
DOI : 10.1109/TAP.2011.2163772
URL : https://hal.archives-ouvertes.fr/hal-00777454
Modern transmission line theory and applications, 1979. ,
Transmission lines [12] S. J. Orfanidis, Electromagnetic Waves and Antennas, Handbook of Engineering Electromagnetics, pp.185-211, 2004. ,
Elements of Soliton Theory, 1980. ,
The inverse scattering transformation and the theory of solitons: an introduction, 1981. ,
Scattering analysis and synthesis of wave trains, The Journal of the Australian Mathematical Society. Series B. Applied Mathematics, vol.9, issue.01, pp.44-63, 1983. ,
DOI : 10.1103/PhysRevLett.19.1095
An efficient algorithm for solving Zakharov-Shabat inverse scattering problem, IEEE Transactions on Antennas and Propagation, vol.50, issue.6, pp.807-811, 2002. ,
DOI : 10.1109/TAP.2002.1017660
A numerical solution to the Zakharov-Shabat inverse scattering problem, IEEE Transactions on Antennas and Propagation, vol.39, issue.1, pp.74-79, 1991. ,
DOI : 10.1109/8.64438
