Solving ill-posed Image Processing problems using Data Assimilation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Data Assimilation is a mathematical framework used in environmental sciences to improve forecasts performed by meteorological, oceanographic or air quality simulation models. Data Assimilation techniques require the resolution of a system with three components: one describing the temporal evolution of a state vector, one coupling the observations to this state vector, and one defining the initial condition. In this report we use this framework to study a class of ill-posed Image Processing problems, usually solved by spatial and temporal regularization techniques. A generic approach is proposed to convert an ill-posed Image Processing problem in terms of a Data Assimilation system. This method is illustrated on the determination of optical flow from an image sequence. The main advantage of the resulting software is the use of a quality criteria on observations for weighting their contribution in the estimation process and of a dynamic model to ensure a relevant temporal regularity of the result.
RR-6879.pdf (1.09 Mo) Télécharger le fichier
inria-00368890 , version 1 (17-03-2009)
inria-00368890 , version 2 (18-03-2009)
  • HAL Id : inria-00368890 , version 2
Dominique Béréziat, Isabelle Herlin. Solving ill-posed Image Processing problems using Data Assimilation. [Research Report] RR-6879, INRIA. 2009, pp.33. ⟨inria-00368890v2⟩
113 Consultations
321 Téléchargements
