A Chemical Interpretation of GSML Programs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
GSML is a programming language that has been designed for grid end-users to overcome the programming hurdle and the high learning curve associated with Grid infrastructures that are complex distributed computing systems. This paper defines its formal semantics in terms of a chemical programming language called HOCL. This translation of GSML programs into HOCL gives a precise definition of the concepts of GSML, especially sessions. The semantics also bridges the GSML and chemical computing paradigms.
Fichier non déposé
inria-00369220 , version 1 (18-03-2009)
Xingwu Liu, Yann Radenac, Jean-Pierre Banâtre, Thierry Priol, Zhiwei Xu. A Chemical Interpretation of GSML Programs. Proceedings of Seventh International Conference on Grid and Cooperative Computing, Shenzhen Institute of Advanced Technology (SIAT), CAS China, Oct 2008, Shenzhen, China. pp.459 -- 466, ⟨10.1109/GCC.2008.5⟩. ⟨inria-00369220⟩
77 Consultations
0 Téléchargements
