Active set methods for the elastic-net ? a regularization for l1-minimization. preprint, 2009. ,
Sparse Deconvolution for Peak Picking and Ion Charge Estimation in Mass Spectrometry, 2008. ,
DOI : 10.1007/978-3-642-12110-4_43
An iterative thresholding algorithm for linear inverse problems with a sparsity constraint, Communications on Pure and Applied Mathematics, vol.58, issue.11, pp.1413-1457, 2004. ,
DOI : 10.1002/cpa.20042
Elastic-net regularization in learning theory. ArXiv e-prints, 2008. ,
Fast solution of ? 1 -norm minimization problems when the solution may be sparse, IEEE Transactions on Information Theory, vol.54, issue.11, pp.4789-4812, 2008. ,
Gradient projection for sparse reconstruction: Applications to compressed sensing and other inverse problems, IEEE Journal of Selected Topics in Signal Processing, vol.4, pp.586-597, 2007. ,
A semismooth Newton method for Tikhonov functionals with sparsity constraints, Inverse Problems, vol.24, issue.3, p.35007, 2008. ,
DOI : 10.1088/0266-5611/24/3/035007
Fixed-Point Continuation for $\ell_1$-Minimization: Methodology and Convergence, SIAM Journal on Optimization, vol.19, issue.3, pp.1107-1130, 2008. ,
DOI : 10.1137/070698920
Efficient sparse coding algorithms, Proceedings of the Neural Information Processing Systems (NIPS), 2006. ,
NITPICK: peak identification for mass spectrometry data, BMC Bioinformatics, vol.9, issue.1, p.355, 2008. ,
DOI : 10.1186/1471-2105-9-355
URL : http://doi.org/10.1186/1471-2105-9-355
Regularization and variable selection via the elastic net, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.5, issue.2, pp.301-320, 2005. ,
DOI : 10.1073/pnas.201162998
