Using a magnetometer to image a two-dimensional current distribution, J. App. phys, vol.65, pp.361-372, 1989. ,
AN ITERATIVE THRESHOLDING ALGORITHM FOR THE NEURAL CURRENT IMAGING, Applied and Industrial Mathematics in Italy III ,
DOI : 10.1142/9789814280303_0012
An introduction to frames and Riesz bases, 2003. ,
Accelerated Projected Gradient Method for Linear Inverse Problems with Sparsity Constraints, Journal of Fourier Analysis and Applications, vol.22, issue.1, pp.764-792, 2008. ,
DOI : 10.1007/s00041-008-9039-8
An iterative thresholding algorithm for linear inverse problems with a sparsity constraint, Communications on Pure and Applied Mathematics, vol.58, issue.11, pp.1413-1457, 2004. ,
DOI : 10.1002/cpa.20042
Regularization of inverse problems, 1996. ,
Adaptive iterative thresholding algorithms for magnetoencephalography (MEG), Journal of Computational and Applied Mathematics, vol.221, issue.2, pp.386-395, 2008. ,
DOI : 10.1016/j.cam.2007.10.048
URL : http://doi.org/10.1016/j.cam.2007.10.048
Recovery Algorithms for Vector-Valued Data with Joint Sparsity Constraints, SIAM Journal on Numerical Analysis, vol.46, issue.2, pp.577-613, 2008. ,
DOI : 10.1137/0606668909
Iterative thresholding algorithms, Applied and Computational Harmonic Analysis, vol.25, issue.2, pp.187-208, 2008. ,
DOI : 10.1016/j.acha.2007.10.005
URL : http://doi.org/10.1016/j.acha.2007.10.005
Reconstruction of a current distribution from its magnetic field, Inverse Problem, pp.1127-1146, 2002. ,
An Iterative Algorithm with Joint Sparsity Constraints for Magnetic Tomography ,
DOI : 10.1007/978-94-017-0752-7_3
Basic mathematical and electromagnetic concepts of the biomagnetic inverse problem, Physics in Medicine and Biology, vol.32, issue.1, pp.11-22, 1987. ,
DOI : 10.1088/0031-9155/32/1/004
Applications of SQUID Magnetometers to Biomagnetism and Nondestructive Evaluation, pp.139-228, 2000. ,
