Morphological Diversity and Sparsity for Multichannel Data Restoration, Journal of Mathematical Imaging and Vision, vol.16, issue.11, pp.149-168, 2008. ,
DOI : 10.1007/s10851-008-0065-6
URL : https://hal.archives-ouvertes.fr/hal-00813969
Blind Source Separation: The Sparsity Revolution, of Advances in Imaging and Electron Physics, pp.221-298, 2008. ,
DOI : 10.1016/S1076-5670(08)00605-8
URL : https://hal.archives-ouvertes.fr/hal-00252075
Simultaneous cartoon and texture image inpainting using morphological component analysis (MCA), Applied and Computational Harmonic Analysis, vol.19, issue.3, pp.340-358, 2005. ,
DOI : 10.1016/j.acha.2005.03.005
URL : http://doi.org/10.1016/j.acha.2005.03.005
Dictionary Identifiability from Few Training Samples, EUSIPCO, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00544764
Learning sparse dictionaries for sparse signal representations, IEEE Transactions on signal processing, pp.sub- mitted, 2008. ,
Sparse coding of natural images produces localized, oriented, bandpass receptive fields, 1995. ,
Some experiments on independent component analysis of non-Gaussian processes, Proceedings of the IEEE Signal Processing Workshop on Higher-Order Statistics. SPW-HOS '99, pp.74-77, 1999. ,
DOI : 10.1109/HOST.1999.778697
Sparse code shrinkage: denoising by nonlinear maximum likelihood estimation, Advances in Neural Information Processing Systems 11 (NIPS*98, pp.473-479, 1999. ,
Left picture : Reference (solid line) and estimated (?) spectra for H 2 O ice Right picture : Reference (solid line) and estimated (?) spectra for CO 2 ice Optimally sparse representation in general (non-orthogonal) dictionaries via ? 1 minimization, Proc. Nat. Aca. Sci, vol.6, issue.100, pp.2197-2202, 2003. ,
Low-Rank Approximations with Sparse Factors I: Basic Algorithms and Error Analysis, SIAM Journal on Matrix Analysis and Applications, vol.23, issue.3, pp.706-727, 2002. ,
DOI : 10.1137/S0895479899359631
Spatiotemporal Independent Component Analysis of Event-Related fMRI Data Using Skewed Probability Density Functions, NeuroImage, vol.15, issue.2, pp.407-421, 2002. ,
DOI : 10.1006/nimg.2001.0986
Imposing sparsity on the mixing matrix in independent component analysis, Neurocomputing, vol.49, issue.1-4, pp.151-162, 2002. ,
DOI : 10.1016/S0925-2312(02)00512-X
An iterative thresholding algorithm for linear inverse problems with a sparsity constraint, Communications on Pure and Applied Mathematics, vol.58, issue.11, pp.1413-1457, 2004. ,
DOI : 10.1002/cpa.20042
A fixedpoint continuation method for l1 -regularized minimization with applications to compressed sensing, Tech. Rep, 2007. ,
Gradient Projection for Sparse Reconstruction: Application to Compressed Sensing and Other Inverse Problems, IEEE Journal of Selected Topics in Signal Processing, vol.1, issue.4, 2007. ,
DOI : 10.1109/JSTSP.2007.910281
Why Simple Shrinkage Is Still Relevant for Redundant Representations?, IEEE Transactions on Information Theory, vol.52, issue.12, pp.5559-5569, 2006. ,
DOI : 10.1109/TIT.2006.885522
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.131.8604
The curvelet transform for image denoising, IEEE Transactions on Image Processing, vol.11, issue.6, pp.670-684, 2002. ,
DOI : 10.1109/TIP.2002.1014998
On the decomposition of Mars hyperspectral data by ICA and Bayesian positive source separation, Neurocomputing, vol.71, issue.10-12, 2008. ,
DOI : 10.1016/j.neucom.2007.07.034
URL : https://hal.archives-ouvertes.fr/hal-00272349
