The Two Stage l1 Approach to the Compressed Sensing Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This paper gives new results on the recovery of sparse signals using l1-norm minimization. We introduce a twostage l1 algorithm equivalent to the first two iterations of the alternating l1 relaxation introduced in
65.pdf (86.03 Ko) Télécharger le fichier
inria-00369534 , version 1 (20-03-2009)
  • HAL Id : inria-00369534 , version 1
Stéphane Chrétien. The Two Stage l1 Approach to the Compressed Sensing Problem. SPARS'09 - Signal Processing with Adaptive Sparse Structured Representations, Inria Rennes - Bretagne Atlantique, Apr 2009, Saint Malo, France. ⟨inria-00369534⟩
66 Consultations
77 Téléchargements
