Precise Evaluation of the Efficiency and the Robustness of Stochastic DAG Schedules - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Louis-Claude Canon
Emmanuel Jeannot
This study is devoted to the evaluation of schedules of parallel applications consisting of a set of stochastic tasks having precedence constraints between them. This is an important issue when the goal is to evaluate the efficiency and the robustness of a schedule. In this case, evaluating the makespan consists to evaluate an arithmetic expression with random variables. Results show that the proposed methods provide a reasonable trade-off between precision and computation time.
RR-6895.pdf (593.32 Ko) Télécharger le fichier
inria-00372651 , version 1 (01-04-2009)
inria-00372651 , version 2 (02-04-2009)
  • HAL Id : inria-00372651 , version 2
Louis-Claude Canon, Emmanuel Jeannot. Precise Evaluation of the Efficiency and the Robustness of Stochastic DAG Schedules. [Research Report] RR-6895, INRIA. 2009, pp.22. ⟨inria-00372651v2⟩
209 Consultations
153 Téléchargements
