On exploiting task duplication in parallel program scheduling, IEEE Transactions on Parallel and Distributed Systems, vol.9, issue.9, pp.872-892, 1998. ,
DOI : 10.1109/71.722221
Representing Task and Machine Heterogeneities for Heterogeneous Computing Systems, Tamkang Journal of Science and Engineering, vol.3, issue.3, pp.195-207, 2000. ,
On a measure of divergence between two statistical populations defined by their probability distributions, Bull. Calcutta Math. Soc, vol.35, issue.4, pp.99-109, 1943. ,
Conditional Monte Carlo: A Simulation Technique for Stochastic Network Analysis, Management Science, vol.18, issue.3, pp.207-217, 1971. ,
A Comparison of Robustness Metrics for Scheduling DAGs on Heterogeneous Systems, Heteropar'07, pp.568-567, 2007. ,
Scheduling Strategies for the Bicriteria Optimization of the Robustness and Makespan, 11th International Workshop on Nature Inspired Distributed Computing, 2008. ,
The Greatest of a Finite Set of Random Variables, Operations Research, vol.9, issue.2, pp.145-162, 1961. ,
DOI : 10.1287/opre.9.2.145
Dynamic LCA Queries on Trees, Proceedings of the tenth annual ACM-SIAM symposium on Discrete algorithms, pp.235-244, 1999. ,
DOI : 10.1137/S0097539700370539
A survey of graph layout problems, ACM Computing Surveys, vol.34, issue.3, pp.313-356, 2002. ,
DOI : 10.1145/568522.568523
Bounding the Project Completion Time Distribution in PERT Networks, Operations Research, vol.33, issue.4, pp.862-881, 1985. ,
DOI : 10.1287/opre.33.4.862
Data Structures for Weighted Matching and Nearest Common Ancestors with Linking, Proceedings of the first annual ACM- SIAM symposium on Discrete algorithms, pp.434-443, 1990. ,
Computational complexity of PERT problems, Networks, vol.8, issue.2, pp.139-147, 1988. ,
DOI : 10.1002/net.3230180206
Normally Distributed Activity Durations in PERT Networks, Journal of the Operational Research Society, vol.36, issue.11, pp.1051-11057, 1985. ,
DOI : 10.1057/jors.1985.184
Bounding Distributions for a Stochastic Acyclic Network, Operations Research, vol.19, issue.7, pp.1586-1601, 1971. ,
DOI : 10.1287/opre.19.7.1586
Application of a Technique for Research and Development Program Evaluation, Operations Research, vol.7, issue.5, pp.646-669, 1959. ,
DOI : 10.1287/opre.7.5.646
Distribution of the Time Through a Directed, Acyclic Network, Operations Research, vol.13, issue.1, pp.46-66, 1965. ,
DOI : 10.1287/opre.13.1.46
Statistical Timing Analysis Considering Spatial Correlations using a Single Pert-Like Traversal, Computer Aided Design (ICCAD-2003), pp.621-625, 2003. ,
The Completion Time of PERT Networks, Journal of the Operational Research Society, vol.34, issue.2, pp.155-158, 1983. ,
DOI : 10.1057/jors.1983.27
Robust task scheduling in non-deterministic heterogeneous computing systems, 2006 IEEE International Conference on Cluster Computing, 2006. ,
DOI : 10.1109/CLUSTR.2006.311868
A standard task graph set for fair evaluation of multiprocessor scheduling algorithms, Journal of Scheduling, vol.70, issue.5, pp.379-394, 2002. ,
DOI : 10.1002/jos.116
Monte Carlo Methods and the PERT Problem, Operations Research, vol.11, issue.5, pp.839-860, 1963. ,
Stochastic bounds on execution times of parallel programs, IEEE Transactions on Software Engineering, vol.17, issue.10, pp.1005-1012, 1991. ,
DOI : 10.1109/32.99189
Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-lès ,
