An efficient method for solving an inverse problem for the Richards equation, Journal of Computational and Applied Mathematics, vol.147, issue.1, pp.153-173, 2002. ,
DOI : 10.1016/S0377-0427(02)00430-2
Numerical Optimization ? Theoretical and Practical Aspects, 2003. ,
Multiscale representation for simultaneous estimation of relative permeabilities and capillary pressure (paper SPE 20501), Proceedings of the 65th SPE Annual Technical Conference and Exhibition, 1990. ,
Relative Permeabilities and Capillary Pressure Estimation through Least Square Fitting, ECMOR I, 1st European Conference on the Mathematics of Oil Recovery, pp.721-734, 1992. ,
DOI : 10.3997/2214-4609.201411335
Simultaneous Estimation of Relative Permeabilities and Capillary Pressure, SPE Formation Evaluation, vol.7, issue.04, pp.283-289, 1992. ,
DOI : 10.2118/19680-PA
Improving the centrifuge technique by measuring local saturations, paper SPE 24882, proceedings of the 67th SPE Annual Technical Conference and Exhibition, 1992. ,
Identification of functional parameter in partial differential equations, Identification of Parameters in Distributed Systems, pp.31-48, 1974. ,
New Size $ \times $ Curvature Conditions for Strict Quasiconvexity of Sets, SIAM Journal on Control and Optimization, vol.29, issue.6, pp.1348-1372, 1991. ,
DOI : 10.1137/0329069
On the theory and practice of non-linear least-squares, Advances in Water Resources, vol.14, issue.2, pp.55-63, 1991. ,
DOI : 10.1016/0309-1708(91)90051-O
Quasi-convex sets and size ??? curvature condition, application to nonlinear inversion, Applied Mathematics & Optimization, vol.4, issue.4, pp.129-169, 1991. ,
DOI : 10.1007/BF01447739
Estimation of mobilities and capillary pressure from centrifuge experiments, Inverse Problems in Engineering Mechanics, pp.265-272, 1994. ,
Numerical approximation and identification in a 1-d parabolic degenerated nonlinear diffusion and transport equation, Optimization techniques : Part 1 of Lecture notes in Control and Information Sciences, pp.282-293, 1978. ,
Determination of relative permeabilities nad capillary pressure by an automatic adjustment method (paper SPE 9237), Proceedings of the 1980 SPE Annual Technical Conference and Exhibition, 1980. ,
Mathematic Models and Mixed Finite Elements for Reservoir Simulation:single phase, multiphase and multicomponent flows trough porous media, 1986. ,
Estimation of relative permeabilities in three-phase flow in porous media, Inverse Problems, vol.15, issue.1, pp.33-39, 1999. ,
DOI : 10.1088/0266-5611/15/1/007
URL : https://hal.archives-ouvertes.fr/hal-00955222
Identification de la non-linéarité d'une equation parabolique quasilinéaire, Appli. Math. and Optim, vol.1, issue.2, 1974. ,
An Inverse Problem for the Hydraulic Properties of Porous Media, SIAM Journal on Mathematical Analysis, vol.28, issue.3, pp.611-632 ,
DOI : 10.1137/S0036141095285673
Identification and control problems in petroleum and groudwater modeling, Control problems in industry of Progress in Systems and Control Theory, pp.119-149, 1995. ,
Assessing the validity of a linearized accuracy measure for a nonlinear parameter estimation problem, Inverse Problems, vol.17, issue.5, pp.1373-1390, 2001. ,
DOI : 10.1088/0266-5611/17/5/309
Nonlinearity, Scale, and Sensitivity for Parameter Estimation Problems, SIAM Journal on Scientific Computing, vol.21, issue.6, pp.2096-2113, 2000. ,
DOI : 10.1137/S1064827598339104
Structural identification of nonlinear coefficient functions in transport processers though porous media, Lectures on Applied Mathematics, pp.157-178, 2000. ,
Marginal Solutions to Quasi-Linear Inverse Problems in Geophysics: The Edgehog Method, Geophysical Journal of the Royal Astronomical Society, vol.35, issue.1-3, pp.121-136, 1973. ,
DOI : 10.1111/j.1365-246X.1973.tb02418.x
Most squares inversion, Journal of Geophysical Research, vol.10, issue.5, pp.1027-1030, 1976. ,
DOI : 10.1029/JB081i005p01027
Using Maple for symbolic differentiation to solve inverse problems, Maple Tech, vol.4, pp.32-40, 1997. ,
Relative permeability estimation from displacements experiments, Society of Petroleum Engineers Res. Eng, pp.175-182, 1986. ,
Inversion with a grain of salt, Geophysics, vol.50, issue.1, pp.99-109, 1985. ,
Estimation of three-phase flow functions in porous media, AIChE Journal, vol.42, issue.7, pp.1957-1967, 1996. ,
DOI : 10.1002/aic.690420716
The Levenberg-Marquardt algorithm: Implementation and theory, Numerical Analysis, number 630 in Lecture Notes in Mathematics, pp.105-116 ,
DOI : 10.1137/0111030
Multiscale estimation with spline wavelets, with application to two-phase porous-media flow, Inverse Problems, vol.16, issue.2, pp.315-332, 2000. ,
DOI : 10.1088/0266-5611/16/2/304
Estimation of Capillary Pressure and Relative Permeability Functions From Centrifuge Experiments, SPE Reservoir Engineering, vol.8, issue.04, pp.292-298, 1993. ,
DOI : 10.2118/20805-PA
Inverse Problems in Groundwater Modeling, 1994. ,
DOI : 10.1007/978-94-017-1970-4
Identification of a nonlinear parameter in a parabolic equation from a linear equation, Comp. Appl. Mat, vol.14, pp.157-184, 1995. ,
Application of optimization methods in oil recovery problems The Norwegian Institute of Technology, 1993. ,
Identifiability of Estimates of Two-Phase Reservoir Properties in History Matching, Society of Petroleum Engineers Journal, vol.24, issue.06, pp.697-706, 1984. ,
DOI : 10.2118/12579-PA
Sensibilité et stabilité dans l'estimation des perméabilités relatives et de la pression capillaire 'a partir de mesures de laboratoire, Thèse de Doctorat de l, 1994. ,
