Why are modalities good for Interface Theories? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
In this paper we revisit the fundamentals of interface theories. Methodological considerations call for supporting ``aspects'' and ``assume/guarantee'' reasoning. From these considerations, we show that, in addition to the now classical refinement and substitutability properties of interfaces, two additional operations are needed, namely: conjunction and residuation (or quotient). We draw the attention to the difficulty in handling interfaces having different alphabets --- which calls for alphabet equalization. We show that alphabet equalization must be performed differently for the different operations. Then, we show that Modal Interfaces, as adapted from the original proposal by Kim Larsen, offer the needed flexibility.
RR-6899.pdf (355.97 Ko) Télécharger le fichier
inria-00375098 , version 1 (13-04-2009)
  • HAL Id : inria-00375098 , version 1
Jean-Baptiste Raclet, Eric Badouel, Albert Benveniste, Benoit Caillaud, Roberto Passerone. Why are modalities good for Interface Theories?. [Research Report] RR-6899, INRIA. 2009. ⟨inria-00375098⟩
243 Consultations
190 Téléchargements
