New interface
Reports (Research report)
Revisiting content sharing in wireless ad hoc networks
Mohamed Karim Sbai 1 Chadi Barakat 1
1 PLANETE - Protocols and applications for the Internet
Inria Grenoble - Rhône-Alpes, CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : Classical content sharing applications like BitTorrent can not be directly used in wireless ad hoc networks. When adapting them to these constrained networks, one faces two main problems. On one hand, exchanging content pieces with far nodes yields an important routing overhead. On the other hand, it is necessary to send some content pieces to far nodes to increase the diversity of information in the network, which fosters reciprocity and parallel exchanges. In this paper, we study both of these problems and propose a joint solution for them. Unlike uni-metric approaches, our solution considers relevant performance metrics together as throughput, sharing and routing overhead. We define a new neighbor selection strategy that balances between sharing and diversification efforts and decides on the optimal scope of a node. It also considers the diversification incentives problem. Through extensive simulations, we prove that our solution realizes both better download time and sharing ratio than uni-metric solutions.
Document type :
Complete list of metadata
Cited literature [8 references]  Display  Hide  Download
https://hal.inria.fr/inria-00376521
Contributor : Chadi Barakat Connect in order to contact the contributor
Submitted on : Friday, April 17, 2009 - 5:34:00 PM
Last modification on : Wednesday, October 26, 2022 - 8:15:10 AM
Long-term archiving on: : Thursday, June 30, 2011 - 11:20:59 AM
File
RR-Revisiting.pdf
Identifiers
Collections
Citation
Mohamed Karim Sbai, Chadi Barakat. Revisiting content sharing in wireless ad hoc networks. [Research Report] 2009. ⟨inria-00376521⟩
Share
Metrics
Record views
126
Files downloads
72
