Conference papers
Best Position Algorithms for Top-k Queries
Abstract : The general problem of answering top-k queries can be modeled using lists of data items sorted by their local scores. The most efficient algorithm proposed so far for answering top-k queries over sorted lists is the Threshold Algorithm (TA). However, TA may still incur a lot of useless accesses to the lists. In this paper, we propose two new algorithms which stop much sooner. First, we propose the best position algorithm (BPA) which executes top-k queries more efficiently than TA. For any database instance (i.e. set of sorted lists), we prove that BPA stops as early as TA, and that its execution cost is never higher than TA. We show that the position at which BPA stops can be (m-1) times lower than that of TA, where m is the number of lists. We also show that the execution cost of our algorithm can be (m-1) times lower than that of TA. Second, we propose the BPA2 algorithm which is much more efficient than BPA. We show that the number of accesses to the lists done by BPA2 can be about (m-1) times lower than that of BPA. Our performance evaluation shows that over our test databases, BPA and BPA2 achieve significant performance gains in comparison with TA.
Document type :
Conference papers
Complete list of metadata
Cited literature [28 references]  Display  Hide  Download
https://hal.inria.fr/inria-00378836
Contributor : Reza Akbarinia Connect in order to contact the contributor
Submitted on : Monday, February 15, 2010 - 4:20:54 PM
Last modification on : Wednesday, April 27, 2022 - 3:42:33 AM
Long-term archiving on: : Thursday, June 10, 2010 - 6:32:01 PM
File
VLDB07-_Best_Position_Algorith...
Identifiers
  • HAL Id : inria-00378836, version 1
Citation
Reza Akbarinia, Esther Pacitti, Patrick Valduriez. Best Position Algorithms for Top-k Queries. International Conference on Very Large Data Bases (VLDB), Aug 2007, Vienna, Austria. pp.495-506. ⟨inria-00378836⟩
Share
Metrics
Record views
332
Files downloads
485
