Parallel Local Search on GPU - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Local search algorithms are a class of algorithms to solve complex optimization problems in science and industry. Even if these efficient iterative methods allow to significantly reduce the computational time of the solution exploration space, the iterative process remains costly when very large problem instances are dealt with. As a solution, graphics processing units (GPUs) rep- resent an efficient alternative for calculations instead of traditional CPU. This paper presents a new methodology to design and implement local search algorithms on GPU. Methods such as tabu search, hill climbing or iterated local search present similar concepts that can be parallelized on GPU and then a general cooperative model can be highlighted. In addition, this model can be extended with a hybrid multi-core and multi-GPU approach for multiple local search methods such as multistart. The conclusions from both GPU and multi-GPU experiments indicate significant speed-ups compared to CPU approaches.
rapportGPULUONG.pdf (1.53 Mo) Télécharger le fichier
inria-00380624 , version 1 (04-05-2009)
inria-00380624 , version 2 (04-05-2009)
  • HAL Id : inria-00380624 , version 1
Thé Van Luong, Nouredine Melab, El-Ghazali Talbi. Parallel Local Search on GPU. [Research Report] RR-6915, 2009. ⟨inria-00380624v1⟩
Collections
INRIA-RRRT
438 Consultations
394 Téléchargements
