Competition and cooperation between nodes in Delay Tolerant Networks with Two Hop Routing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
This paper revisits the two-hop forwarding policy in delay tolerant networks (DTNs) using simple probabilistic approaches. Closed form expressions are derived for the main performance measures. We then study competitive and cooperative operation of DTNs and derive the structure of optimal and of equilibrium policies.
RR-6904.pdf (2.54 Mo) Télécharger le fichier
inria-00381030 , version 1 (04-05-2009)
  • HAL Id : inria-00381030 , version 1
Eitan Altman. Competition and cooperation between nodes in Delay Tolerant Networks with Two Hop Routing. [Research Report] RR-6904, INRIA. 2009. ⟨inria-00381030⟩
62 Consultations
96 Téléchargements
