Forcing-based cut-elimination for Gentzen-style intuitionistic sequent calculus
We give a simple intuitionistic completeness proof of Kripke semantics for intuitionistic logic with implication and universal quantification with respect to cut-free intuitionistic sequent calculus. The Kripke semantics is ``simplified'' in the way that the domain remains constant. The proof has been formalised in the Coq proof assistant and by combining soundness with completeness, we obtain an executable cut-elimination procedure. The proof easily extends to the case of the absurdity connective using Kripke models with exploding nodes à la Veldman.
