An Optimistic Mandatory Access Control Model for Distributed Collaborative Editors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Distributed Collaborative Editors (DCE) provide computer support for modifying simultaneously shared documents, such as articles, wiki pages and programming source code, by dispersed users. Controlling access in such systems is still a challenging problem, as they need dynamic access changes and low latency access to shared documents. In this paper, we propose a Mandatory Access Control (MAC) based on replicating the shared document and its authorization policy at the local memory of each user. To deal with latency and dynamic access changes, we use an optimistic access control technique where enforcement of authorizations is retroactive. We show that naive coordination between updates of both copies can create security hole on the shared document by permitting illegal modification, or rejecting legal modification. Finally, we present a novel framework for managing authorizations in collaborative editing work which may be deployed easily on P2P networks.
main.pdf (326.98 Ko) Télécharger le fichier
inria-00381941 , version 1 (06-05-2009)
inria-00381941 , version 2 (18-05-2009)
  • HAL Id : inria-00381941 , version 1
Abdessamad Imine, Asma Cherif, Michaël Rusinowitch. An Optimistic Mandatory Access Control Model for Distributed Collaborative Editors. [Research Report] 2009, pp.20. ⟨inria-00381941v1⟩
Collections
INRIA-RRRT
185 Consultations
236 Téléchargements
