Geometric Inference for Measures based on Distance Functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Foundations of Computational Mathematics Année : 2011
Frédéric Chazal
David Cohen-Steiner
  • Fonction : Auteur
  • PersonId : 833472
Quentin Mérigot
Connectez-vous pour contacter l'auteur
Data often comes in the form of a point cloud sampled from an unknown compact subset of Euclidean space. The general goal of geometric inference is then to recover geometric and topological features (Betti numbers, curvatures,...) of this subset from the approximating point cloud data. In recent years, it appeared that the study of distance functions allows to address many of these questions successfully. However, one of the main limitations of this framework is that it does not cope well with outliers nor with background noise. In this paper, we show how to extend the framework of distance functions to overcome this problem. Replacing compact subsets by measures, we introduce a notion of distance function to a probability distribution in $\R^n$. These functions share many properties with classical distance functions, which makes them suitable for inference purposes. In particular, by considering appropriate level sets of these distance functions, it is possible to associate in a robust way topological and geometric features to a probability measure. We also discuss connections between our approach and non parametric density estimation as well as mean-shift clustering.
RR-6930v2.pdf (405.47 Ko) Télécharger le fichier
inria-00383685 , version 1 (13-05-2009)
inria-00383685 , version 2 (23-06-2010)
Frédéric Chazal, David Cohen-Steiner, Quentin Mérigot. Geometric Inference for Measures based on Distance Functions. Foundations of Computational Mathematics, 2011, 11 (6), pp.733-751. ⟨10.1007/s10208-011-9098-0⟩. ⟨inria-00383685v2⟩
825 Consultations
1250 Téléchargements
