An Occupancy-Depth Generative Model of Multi-view Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
This paper presents an occupancy based generative model of stereo and multi-view stereo images. In this model, the space is divided into empty and occupied regions. The depth of a pixel is naturally determined from the occupancy as the depth of the first occupied point in its viewing ray. The color of a pixel corresponds to the color of this 3D point. This model has two theoretical advantages. First, unlike other occupancy based models, it explicitly models the deterministic relationship between occupancy and depth and, thus, it correctly handles occlusions. Second, unlike depth based approaches, determining depth from the occupancy automatically ensures the coherence of the resulting depth maps. Experimental results computing the MAP of the model using message passing techniques are presented to show the applicability of the model.
GargalloSturmPujades-accv2007.pdf (2.82 Mo) Télécharger le fichier
inria-00384276 , version 1 (14-05-2009)
Pau Gargallo, Peter Sturm, Sergi Pujades. An Occupancy-Depth Generative Model of Multi-view Images. ACCV 2007 - 8th Asian Conference on Computer Vision, Nov 2007, Tokyo, Japan. pp.373-383, ⟨10.1007/978-3-540-76390-1_37⟩. ⟨inria-00384276⟩
172 Consultations
315 Téléchargements
