A controllable, fast and stable basis for vortex based smoke simulation, ACM-EG Proc. Symposium on Computer Animation, pp.25-32, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00402106
Rigid fluid: animating the interplay between rigid bodies and fluid, Proc. SIGGRAPH), pp.377-384, 2004. ,
Simultaneous coupling of fluids and deformable bodies, ACM-EG Proc. Symposium on Computer Animation, pp.83-89, 2006. ,
Visual simulation of smoke, Computer Graphics Proc. (Proc. SIGGRAPH), pp.15-22, 2001. ,
Animating gases with hybrid meshes, Proc. SIGGRAPH), pp.904-909, 2005. ,
Complementarity problems in GAMS and the PATH solver, Tech. Rep. Mathematical Programming, pp.98-110, 1998. ,
Practical animation of liquids, Computer Graphics Proc. (Proc. SIGGRAPH), pp.23-30, 2001. ,
Realistic animation of liquids. Graphical models and image processing: GMIP 58, pp.471-483, 1996. ,
Simulating fluid?solid interaction, Graphics Interface, pp.31-38, 2003. ,
A second order accurate symmetric discretization of the Poisson equation on irregular domains, J. Comput. Phys, vol.176, pp.205-227, 2002. ,
Nonconvex rigid bodies with stacking, Proc. SIGGRAPH), pp.871-878, 2003. ,
Coupling water and smoke to thin deformable and rigid shells, Proc. SIGGRAPH), pp.973-981, 2005. ,
Numerical Calculation of Time-Dependent Viscous Incompressible Flow of Fluid with Free Surface, Phys. Fluids, vol.8, pp.2182-2189, 1965. ,
An arbitrary Lagrangian-Eulerian computing method for all flow speeds, J. Comput. Phys, vol.14, issue.3, pp.227-253, 1974. ,
A unified approach for modeling complex occlusions in fluid simulations, Proc. SIGGRAPH Sketches & applications, 2003. ,
Efficient simulation of large bodies of water by coupling two and three dimensional techniques, Proc. SIGGRAPH), pp.805-811, 2006. ,
A Cartesian grid embedded boundary method for Poisson's equation on irregular domains, J. Comput. Phys, vol.147, issue.1, pp.60-85, 1998. ,
A unified Lagrangian approach to solidfluid animation, Eurographics Symposium on Point-Based Graphics, pp.125-148, 2005. ,
A representation of curved boundaries for the solution of the Navier-Stokes equations on a staggered three-dimensional Cartesian grid, J. Comput. Phys, vol.184, pp.1-36, 2003. ,
Fluid animation with dynamic meshes, Proc. SIGGRAPH), pp.820-825, 2006. ,
An immersed interface method for viscous incompressible flows involving rigid and flexible boundaries, J. Comp. Phys, vol.220, pp.109-138, 2006. ,
Sharp interface Cartesian grid method II: A technique for simulating droplet interactions with surfaces of arbitrary shape, J. Comput. Phys, vol.210, issue.1, pp.32-54, 2005. ,
Simulating water and smoke with an octree data structure, Proc. SIGGRAPH), pp.457-462, 2004. ,
Sharp interface Cartesian grid method I: An easily implemented technique for 3D moving boundary computations, J. Comput. Phys, vol.210, issue.1, pp.1-31, 2005. ,
Directable photorealistic liquids, ACM-EG Proc. Symposium on Computer Animation, pp.193-202, 2004. ,
Cartesian grid fluid simulation with irregular boundary voxels, Proc. SIGGRAPH Sketches & applications, 2005. ,
A Cartesian grid embedded boundary method for the heat equation and Poisson's equation in three dimensions, J. Comput. Phys, vol.211, issue.2, pp.531-550, 2006. ,
The simulation of fluid-rigid body interaction, Proc. SIGGRAPH Sketches & applications, 2002. ,
An algorithm for modelling the interaction of a flexible rod with a two-dimensional high-speed flow, Int. J. Numer. Meth. Engng, vol.64, pp.1057-1077, 2005. ,
Free surface flows with moving and deforming objects with LBM, Vision, Modeling, and Visualization, 2006. ,
A sharp interface Cartesian grid method for simulating flows with complex moving boundaries, J. Comput . Phys, vol.174, pp.345-380, 2001. ,
Animating sand as a fluid, Proc. SIGGRAPH), pp.965-972, 2005. ,
