High-performance parallel and distributed computing for the BMIeigenvalue problem. Parallel and Distributed Processing Symposium, Proceedings International, IPDPS 2002, Abstracts and CD- ROM, pp.71-78, 2002. ,
Distributed computing with hierarchical master-worker paradigm for parallel branch and bound algorithm, CCGrid 2003. 3rd IEEE/ACM International Symposium on Cluster Computing and the Grid, 2003. Proceedings., pp.156-163, 2003. ,
DOI : 10.1109/CCGRID.2003.1199364
Solving large quadratic assignment problems on computational grids, Mathematical Programming, pp.563-588, 2002. ,
DOI : 10.1007/s101070100255
Load balancing for heterogeneous clusters of PCs, Future Generation Computer Systems, vol.18, issue.3, pp.389-400, 2002. ,
DOI : 10.1016/S0167-739X(01)00058-9
Efficient solutions for mapping parallel programs, European Conference on Parallel Processing, pp.379-390, 1995. ,
DOI : 10.1007/BFb0020479
Pico: An Object-Oriented Framework for Parallel Branch and Bound, Research Report, vol.40, 2000. ,
DOI : 10.1016/S1570-579X(01)80014-8
XtremWeb : une plate-forme pour l'étude expérimentale du calcul global pair-à-pair, 2003. ,
DIB---a distributed implementation of backtracking, ACM Transactions on Programming Languages and Systems, vol.9, issue.2, pp.235-256, 1987. ,
DOI : 10.1145/22719.24067
The Complexity of Flowshop and Jobshop Scheduling, Mathematics of Operations Research, vol.1, issue.2, pp.117-129, 1976. ,
DOI : 10.1287/moor.1.2.117
A problem-specific fault-tolerance mechanism for asynchronous, distributed systems, Proceedings 2000 International Conference on Parallel Processing, pp.21-24, 2000. ,
DOI : 10.1109/ICPP.2000.876065
BOB: A unified platform for implementing branch-and-bound like algorithms, Research Report, vol.9516, 1995. ,
Parallel Branch and Bound Algorithms on Internet Connected Workstations, High Performance Computing and Communcations, pp.768-775, 2005. ,
DOI : 10.1007/11557654_87
A Simple and Effective Iterative Greedy Algorithm for the Flowshop Scheduling Problem, Technical Report, submitted to European Journal of Operational Research, 2004. ,
The GST load balancing algorithm for parallel and distributed systems, International Journal of Approximate Reasoning, vol.19, issue.1-2, pp.39-56, 1998. ,
DOI : 10.1016/S0888-613X(98)00017-6
Benchmarks for basic scheduling problems, European Journal of Operational Research, vol.64, issue.2, pp.278-285, 1993. ,
DOI : 10.1016/0377-2217(93)90182-M
Alps: A Framework for Implementing Parallel Tree Search Algorithms, The Proceedings of the Ninth INFORMS Computing Society Conference, 2005. ,
DOI : 10.1007/0-387-23529-9_21
