Preprints, Working Papers, ...
A semantic method to prove strong normalization from weak normalization
Denis Cousineau 1, 2
2 TYPICAL - Types, Logic and computing
LIX - Laboratoire d'informatique de l'École polytechnique [Palaiseau], Inria Saclay - Ile de France
Abstract : Deduction modulo is an extension of first-order predicate logic where axioms are replaced by rewrite rules and where many theories, such as arithmetic, simple type theory and some variants of set theory, can be expressed. An important question in deduction modulo is to find a condition of the theories that have the strong normalization property. In a previous paper we proposed a refinement of the notion of model for theories expressed in deduction modulo, in a way allowing not only to prove soundness, but also completeness: a theory has the strong normalization property if and only if it has a model of this form. In this paper, we present how we can use these techniques to prove that all weakly normalizing theories expressed in minimal deduction modulo, are strongly normalizing.
Document type :
Complete list of metadata
Cited literature [17 references]  Display  Hide  Download
https://hal.inria.fr/inria-00385520
Contributor : Denis Cousineau Connect in order to contact the contributor
Submitted on : Tuesday, May 19, 2009 - 2:53:24 PM
Last modification on : Friday, February 4, 2022 - 3:17:00 AM
Long-term archiving on: : Monday, October 15, 2012 - 10:45:32 AM
File
RiceSaladLambdaModulo.pdf
Identifiers
  • HAL Id : inria-00385520, version 1
Collections
Citation
Denis Cousineau. A semantic method to prove strong normalization from weak normalization. 2009. ⟨inria-00385520⟩
Share
Metrics
Record views
137
Files downloads
59
