Building curves with arbitrary small MOV degree over finite prime fields - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Cryptology Année : 2005
We present a fast algorithm for building ordinary elliptic curves over finite prime fields having arbitrary small MOV degree. The elliptic curves are obtained using complex multiplication by any desired discriminant.
Fichier non déposé
inria-00386299 , version 1 (20-05-2009)
  • HAL Id : inria-00386299 , version 1
Régis Dupont, Andreas Enge, François Morain. Building curves with arbitrary small MOV degree over finite prime fields. Journal of Cryptology, 2005, 18 (2), pp.79-89. ⟨inria-00386299⟩
167 Consultations
0 Téléchargements
