Parametric estimation and tests through divergences and the duality technique, Journal of Multivariate Analysis, vol.100, issue.1, 2008. ,
DOI : 10.1016/j.jmva.2008.03.011
Minimization of ??-divergences on sets of signed measures, Studia Scientiarum Mathematicarum Hungarica, vol.43, issue.4, pp.403-442, 2006. ,
DOI : 10.1556/SScMath.43.2006.4.2
URL : https://hal.archives-ouvertes.fr/hal-00467649
Propriétés d'existence et propriétés topologiques des fonctions de dépendance avec applicationsàapplicationsà la convergence des types pour des lois multivariées, C. R. Acad. Sci. Paris Sér. A-B, vol.288, issue.2, pp.145-148, 1979. ,
Non parametric tests of independence, Nonparametric asymptotic statistics (Proc. Conf, pp.95-107, 1979. ,
DOI : 10.2307/3315014
A Kolmogorov-Smirnov type test for independence and multivariate samples, Rev. Roumaine Math. Pures Appl, vol.26, issue.2, pp.213-226, 1981. ,
A semiparametric estimation procedure of dependence parameters in multivariate families of distributions, Biometrika, vol.82, issue.3, pp.543-552, 1995. ,
DOI : 10.1093/biomet/82.3.543
Parametric Families of Multivariate Distributions with Given Margins, Journal of Multivariate Analysis, vol.46, issue.2, pp.262-282, 1993. ,
DOI : 10.1006/jmva.1993.1061
Multivariate models and dependence concepts, volume 73 of Monographs on Statistics and Applied Probability, 1997. ,
An introduction to copulas, Lecture Notes in Statistics, vol.139, 1999. ,
DOI : 10.1007/978-1-4757-3076-0
Multivariate survival distributions, Journal of Nonparametric Statistics, vol.39, issue.3-4, pp.343-354, 1994. ,
DOI : 10.2307/2341080
Asymptotic Normality of Nonparametric Tests for Independence, The Annals of Statistics, vol.2, issue.5, pp.892-910, 1974. ,
DOI : 10.1214/aos/1176342812
Fonctions de répartitionrépartitionà n dimensions et leurs marges, Publ. Inst. Statist. Univ. Paris, vol.8, pp.229-231, 1959. ,
Semiparametric estimation in copula models, Canadian Journal of Statistics, vol.87, issue.3, pp.357-375, 2005. ,
DOI : 10.1002/cjs.5540330304
On assessing the association for bivariate current status data, Biometrika, vol.87, issue.4, pp.879-893, 2000. ,
DOI : 10.1093/biomet/87.4.879
