Conference papers
Asymptotic properties of functional maximum-likelihood ARH parameter estimators
Abstract : In this paper, the asymptotic distribution of the maximum likelihood functional estimators of the operators involved in the formulation of gaussian ARH(1) models is studied in the case of imcomplete functional data (see Ruiz-Medina and Salmerón, 2009, Ruiz-Medina, Salmerón and Angulo, 2007, and Salmerón and Ruiz-Medina, 2009). Specifically, an extension to the functional context of the Titterington (1983, 1984) results is derived by applying a Robbins-Monro-type invariance procedure. The asymptotic properties of the functional predictors computed by applying Kalman filtering are then obtained from a functional version of Bosq (2008) results.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00386676
Contributor : Conférence Jds2009 Connect in order to contact the contributor
Submitted on : Friday, May 22, 2009 - 9:12:17 AM
Last modification on : Friday, May 22, 2009 - 9:12:17 AM
Identifiers
  • HAL Id : inria-00386676, version 1
Collections
Citation
Maria Dolores Ruiz-Medina. Asymptotic properties of functional maximum-likelihood ARH parameter estimators. 41èmes Journées de Statistique, SFdS, Bordeaux, 2009, Bordeaux, France, France. ⟨inria-00386676⟩
Share
Metrics
Record views
177
