A note on construction and application of balanced n-ary designs, Sankhya Ser B, vol.49, pp.192-196, 1987. ,
A list of balanced ternary designs with R 15, and some necessary existence conditions, Ars Combin, vol.16, pp.235-258, 1983. ,
Balanced n-ary designs: a combinatorial survey and some new results, Ars Combin, vol.17, pp.37-72, 1984. ,
A census of (9;1;3;2) balanced ternary designs Construction of balanced n-ary block designs, J.Combin.Math.Combin.Comput. Ann. Inst. Statist. Math, vol.2322, pp.389-393, 1970. ,
Recursive methods for construction of balanced n-ary block design, Serdica Math, J, vol.31, pp.189-200, 2005. ,
Constructions of some balanced ternary designs from one factorization , Utilitas math, pp.213-217, 1992. ,
On ternary designs with a speci?ed number of blocks with repeated elements, Ars Combin, vol.40, pp.129-142, 1995. ,
Construction of balanced n-ary design, Utilitas Math Construction of balanced n-ary block designs and their uses Balanced nested designs and balanced n-ary designs, Jour. Ind. Statist. Assoc. J.S.P.I, vol.1111, issue.37, pp.3-31, 1968. ,
A construction of balanced ternary designs, Ars Combin The design and analysis of block experiments, J.Roy.Stat.Soc.Ser B, vol.3314, pp.276-278, 1952. ,
