Improving on computation of homogenized coefficients in the periodic and quasi-periodic settings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
In quasi-periodic or nonlinear periodic homogenization, the corrector problem must be in general set on the whole space. Numerically computing the homogenization coefficient therefore implies a truncation error, due to the fact that the problem is approximated on a bounded, large domain. We present here an approach that improves the rate of convergence of this approximation.
blanc-lebris.pdf (313.91 Ko) Télécharger le fichier
inria-00387214 , version 1 (24-05-2009)
  • HAL Id : inria-00387214 , version 1
Xavier Blanc, Claude Le Bris. Improving on computation of homogenized coefficients in the periodic and quasi-periodic settings. [Research Report] 2009, pp.35. ⟨inria-00387214⟩
507 Consultations
395 Téléchargements
