Modern Compiler Implementation in ML, 1998. ,
DOI : 10.1017/CBO9780511811449
Optimal coalescing challenge, 2000. ,
Optimal spilling for CISC machines with few registers, PLDI'01, pp.243-253, 2001. ,
Spill code minimization via interference region spilling, PLDI '97, pp.287-295, 1997. ,
DOI : 10.1145/258916.258941
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.41.3362
A Study of Spilling and Coalescing in Register Allocation as Two Separate Phases, 2008. ,
URL : https://hal.archives-ouvertes.fr/tel-00403504
On the Complexity of Register Coalescing, International Symposium on Code Generation and Optimization (CGO'07), 2007. ,
DOI : 10.1109/CGO.2007.26
Register Allocation via Graph Coloring, 1992. ,
Polynomial time graph coloring register allocation, Workshop on Logic and Synthesis, 2005. ,
Register allocation and spilling via graph coloring, Symposium on Compiler Construction, pp.98-105, 1982. ,
The priority-based coloring approach to register allocation, ACM TOPLAS, vol.12, issue.4, pp.501-536, 1990. ,
Live range splitting in a graph coloring register allocator, CC '98, pp.174-187, 1998. ,
A faster optimal register allocator, MICRO 35, pp.245-256, 2002. ,
Iterated register coalescing, ACM Transactions on Programming Languages and Systems, vol.18, issue.3, pp.300-324, 1996. ,
DOI : 10.1145/229542.229546
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.34.4803
Optimal and Near-optimal Global Register Allocation Using 0-1 Integer Programming, Software: Practice and Experience, vol.26, issue.8, pp.929-965, 1996. ,
DOI : 10.1002/(SICI)1097-024X(199608)26:8<929::AID-SPE40>3.0.CO;2-T
Optimal and near-optimal global register allocation, 1996. ,
A Fast Cutting-Plane Algorithm for Optimal Coalescing, CC'07, pp.111-125, 2007. ,
DOI : 10.1007/978-3-540-71229-9_8
Efficient register allocation via coloring using clique separators, ACM Transactions on Programming Languages and Systems, vol.16, issue.3, pp.370-386, 1994. ,
DOI : 10.1145/177492.177499
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.157.1947
Load/store range analysis for global register allocation, PLDI'93, pp.268-277, 1993. ,
Fusion-based register allocation, ACM TOPLAS, vol.22, 1997. ,
Optimistic register coalescing, PACT '98, p.196, 1998. ,
DOI : 10.1145/1011508.1011512
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.33.9438
Extended Linear Scan: An Alternate Foundation for Global Register Allocation, CC'07, pp.141-155, 2007. ,
DOI : 10.1007/978-3-540-71229-9_10
Decomposition by clique separators, Discrete Mathematics, vol.55, issue.2, pp.221-232, 1985. ,
DOI : 10.1016/0012-365X(85)90051-2
Introduction to Graph Theory, 2000. ,
The maximum k-colorable subgraph problem for chordal graphs, Information Processing Letters, vol.24, issue.2, pp.133-137, 1987. ,
DOI : 10.1016/0020-0190(87)90107-4
