Tight lower bounds for query processing on streaming and external memory data, Theoretical Computer Science, vol.380, issue.1-2, pp.199-217, 2007. ,
DOI : 10.1016/j.tcs.2007.02.062
Machine models and lower bounds for query processing, Proceedings of the twenty-sixth ACM SIGMOD-SIGACT-SIGART symposium on Principles of database systems , PODS '07, pp.41-52, 2007. ,
DOI : 10.1145/1265530.1265537
Buffering in query evaluation over XML streams, Proceedings of the twenty-fourth ACM SIGMOD-SIGACT-SIGART symposium on Principles of database systems , PODS '05, pp.216-227, 2005. ,
DOI : 10.1145/1065167.1065195
Validating streaming XML documents, Proceedings of the twenty-first ACM SIGMOD-SIGACT-SIGART symposium on Principles of database systems , PODS '02, pp.53-64, 2002. ,
DOI : 10.1145/543613.543622
Constant-Memory Validation of Streaming XML Documents Against DTDs, pp.299-313, 2007. ,
DOI : 10.1007/11965893_21
On the memory requirements of xpath evaluation over xml streams, J. Comput. Syst. Sci, pp.73-391, 2007. ,
Stream firewalling of xml constraints, Proceedings of the 2008 ACM SIGMOD international conference on Management of data , SIGMOD '08, pp.487-498, 2008. ,
DOI : 10.1145/1376616.1376667
SPEX: Streamed and Progressive Evaluation of XPath, IEEE Transactions on Knowledge and Data Engineering, vol.19, issue.7, pp.934-949, 2007. ,
DOI : 10.1109/TKDE.2007.1063
Online evaluation of regular tree queries, Nordic Journal of Computing, vol.13, pp.1-26, 2006. ,
