Online adaptation of reference trajectories for the control of walking systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Robotics and Autonomous Systems Année : 2006
A simple and widely used way to make a robotic system walk without falling is to make it track a reference tra jectory in one way or another, but the stability obtained this way may be limited and even small perturbations may lead to a fall. We propose here a series of heuristics to improve the stability that can be obtained from such a tracking control law, through an online adaptation of the choice of the reference tra jectory being tracked. Encouraging simulations are obtained in the end on a simple planar biped model.
FinalVersion.pdf (289.62 Ko) Télécharger le fichier
inria-00390423 , version 1 (02-06-2009)
Pierre-Brice Wieber, Christine Chevallereau. Online adaptation of reference trajectories for the control of walking systems. Robotics and Autonomous Systems, 2006, 54 (7), pp.559-566. ⟨10.1016/j.robot.2006.04.007⟩. ⟨inria-00390423⟩
447 Consultations
482 Téléchargements
