Wavelets, spectrum analysis and 1/f processes, Lecture Notes in Statistics: Wavelets and Statistics, vol.103, pp.15-29, 1995. ,
DOI : 10.1007/978-1-4612-2544-7_2
URL : https://hal.archives-ouvertes.fr/inria-00570663
Particle-Imaging Techniques for Experimental Fluid Mechanics, Annual Review of Fluid Mechanics, vol.23, issue.1, pp.261-304, 1991. ,
DOI : 10.1146/annurev.fl.23.010191.001401
A database and evaluation methodology for optical flow, Int. Conf. on Comp. Vis., ICCV, 2007. ,
Performance of optical flow techniques, International Journal of Computer Vision, vol.54, issue.1, pp.43-77, 1994. ,
DOI : 10.1007/BF01420984
A three-frame algorithm for estimating two-component image motion, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.14, issue.9, pp.886-895 ,
DOI : 10.1109/34.161348
Report 1 on production and diffusion of fluid mechanics images and data. Fluid project deliverable 1.2, 2005. ,
Horizontal velocity structure functions in the upper troposphere and lower stratosphere: 1. Observations, Journal of Geophysical Research: Atmospheres, vol.25, issue.D10, pp.223-232, 2001. ,
DOI : 10.1029/2000JD900814
Pressure image assimilation for atmospheric motion estimation, Tellus A, vol.28, issue.3, pp.160-178, 2008. ,
DOI : 10.1111/j.1600-0870.2008.00370.x
URL : https://hal.archives-ouvertes.fr/inria-00273838
Fluid experimental flow estimation based on an optical-flow scheme, Experiments in Fluids, vol.10, issue.5, pp.80-97, 2006. ,
DOI : 10.1007/s00348-005-0048-y
URL : https://hal.archives-ouvertes.fr/halshs-00008138
Dense estimation of fluid flows, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.24, issue.3, pp.365-380, 2002. ,
DOI : 10.1109/34.990137
URL : https://hal.archives-ouvertes.fr/hal-00329724
A Low Dimensional Fluid Motion Estimator, International Journal of Computer Vision, vol.21, issue.3, pp.329-349, 2007. ,
DOI : 10.1007/s11263-007-0037-0
URL : https://hal.archives-ouvertes.fr/inserm-00140892
Saturated-cascade similitude theory of gravity wave spectra, Journal of Geophysical Research: Atmospheres, vol.1, issue.Suppl. 6, pp.799-818, 1997. ,
DOI : 10.1029/97JD02151
The existence of geometrical density-image transformations corresponding to object motion, Computer Vision, Graphics, and Image Processing, vol.44, issue.2, pp.155-174, 1988. ,
DOI : 10.1016/S0734-189X(88)80003-3
Wavelet analysis and synthesis of fractional Brownian motion, IEEE Transactions on Information Theory, vol.38, issue.2, pp.910-917, 1992. ,
DOI : 10.1109/18.119751
Velocity field statistics in homogeneous steady turbulence obtained using a high-resolution direct numerical simulation, Physics of Fluids, vol.14, issue.3, pp.1065-1081, 2002. ,
DOI : 10.1063/1.1448296
Developments in Maximum Entropy Data Analysis, Maximum Entropy and Bayesian Methods, pp.53-71, 1989. ,
DOI : 10.1007/978-94-015-7860-8_4
Three-Dimensional Motion Estimation of Atmospheric Layers From Image Sequences, IEEE Transactions on Geoscience and Remote Sensing, vol.46, issue.8, pp.2385-2396, 2008. ,
DOI : 10.1109/TGRS.2008.918167
URL : https://hal.archives-ouvertes.fr/hal-00670348
Layered Estimation of Atmospheric Mesoscale Dynamics From Satellite Imagery, IEEE Transactions on Geoscience and Remote Sensing, vol.45, issue.12, pp.4087-4104, 2007. ,
DOI : 10.1109/TGRS.2007.906156
URL : https://hal.archives-ouvertes.fr/hal-00596167
Dynamic consistent correlation-variational approach for robust optical flow estimation, Experiments in Fluids, vol.28, issue.3, pp.595-608, 2008. ,
DOI : 10.1007/s00348-008-0567-4
URL : https://hal.archives-ouvertes.fr/hal-00914361
Validation of subgradient optimization, Mathematical Programming, vol.8, issue.1, pp.62-88, 1974. ,
DOI : 10.1007/BF01580223
Robust regression using iteratively reweighted least-squares, Communications in Statistics - Theory and Methods, vol.3, issue.9, pp.813-827, 1977. ,
DOI : 10.1214/aos/1176342503
Determining optical flow, Artificial Intelligence, vol.17, issue.1-3, pp.185-203, 1981. ,
DOI : 10.1016/0004-3702(81)90024-2
Probability Theory: The Logic of Science, 2003. ,
DOI : 10.1017/CBO9780511790423
The local structure of turbulence in inompressible viscous fluid for very large reynolds number, Dolk. Akad. Nauk SSSR, vol.30, pp.301-306, 1941. ,
Inertial Ranges in Two-Dimensional Turbulence, Physics of Fluids, vol.10, issue.7, pp.1417-1423, 1967. ,
DOI : 10.1063/1.1762301
Scaling structure of the velocity statistics in atmospheric boundary layers, Physical Review E, vol.61, issue.1, pp.407-421, 2000. ,
DOI : 10.1103/PhysRevE.61.407
Can the atmospheric kinetic energy spectrum be explained by two-dimensional turbulence?, Journal of Fluid Mechanics, vol.388, 1999. ,
DOI : 10.1017/S0022112099004851
Horizontal velocity structure functions in the upper troposphere and lower stratosphere: 2. Theoretical considerations, Journal of Geophysical Research: Atmospheres, vol.164, issue.D10, pp.233-241, 2001. ,
DOI : 10.1029/2000JD900815
Fluid flow and optical flow, Journal of Fluid Mechanics, vol.51, issue.253, 2008. ,
DOI : 10.1023/A:1013614317973
Bayesian Interpolation, Neural Computation, vol.49, issue.3, pp.415-447, 1992. ,
DOI : 10.1093/comjnl/11.2.185
Kinetic energy spectrum of large-and mesoscale atmospheric processes, Nature, vol.9, issue.5972, pp.36-38, 1984. ,
DOI : 10.1038/310036a0
Variational Assimilation of Fluid Motion from Image Sequence, SIAM Journal on Imaging Sciences, vol.1, issue.4, 2008. ,
DOI : 10.1137/080713896
URL : https://hal.archives-ouvertes.fr/hal-00596149
Recovering isotropic statistics in turbulence simulations: The Kolmogorov 4/5th law, Physical Review E, vol.68, issue.2, 2003. ,
DOI : 10.1103/PhysRevE.68.026310
Energy Spectrum of Atmospheric Turbulence: Quasigeostrophic Two-Level Model Simulation, Journal of the Atmospheric Sciences, vol.60, issue.6, pp.824-835, 2003. ,
DOI : 10.1175/1520-0469(2003)060<0824:TKAKES>2.0.CO;2
Splines: a perfect fit for signal and image processing, IEEE Signal Processing Magazine, vol.16, issue.6, pp.22-38, 1999. ,
DOI : 10.1109/79.799930
A theoretical framework for convex regularizers in pde-based computation of image motion, Int. J. Computer Vision, pp.245-264, 2004. ,
Discrete Orthogonal Decomposition and Variational Fluid Flow Estimation, Journal of Mathematical Imaging and Vision, vol.34, issue.2, pp.67-80, 2007. ,
DOI : 10.1007/s10851-007-0014-9
Campus universitaire de Beaulieu -35042 Rennes Cedex (France) Unité de recherche INRIA Futurs : Parc Club Orsay Université -ZAC des Vignes 4 ,
Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-lès ,
Domaine de Voluceau -Rocquencourt -BP 105 -78153 Le Chesnay Cedex (France) Unité de recherche INRIA Sophia Antipolis : 2004, route des Lucioles -BP 93 -06902 ,
BP 105 -78153 Le Chesnay Cedex (France) ?tt??????????r????r ,
