Nonlinear Predictive Control and Moving Horizon Estimation ??? An Introductory Overview, Advances in Control, Highlights of ECC'99, pp.391-449, 1999. ,
DOI : 10.1007/978-1-4471-0853-5_19
Forward Dynamics, Elimination Methods, and Formulation Stiffness in Robot Simulation, The International Journal of Robotics Research, vol.16, issue.6, pp.749-758, 1997. ,
DOI : 10.1177/027836499701600603
Ein Kollokationsverfahren zur numerischen Lösung allgemeiner Mehrpunktrandwertaufgaben mit Schalt? und Sprungbedingungen mit Anwendungen in der optimalen Steuerung und der Parameteridentifizierung, 1984. ,
Active set vs. interior point strategies for model predictive control, Proceedings of the 2000 American Control Conference. ACC (IEEE Cat. No.00CH36334), pp.4229-4233, 2000. ,
DOI : 10.1109/ACC.2000.877018
Dynamic Programming, 1957. ,
Advances in simultaneous strategies for dynamic process optimization, Chemical Engineering Science, vol.57, issue.4, pp.575-593, 2002. ,
DOI : 10.1016/S0009-2509(01)00376-1
Solution of dynamic optimization problems by successive quadratic programming and orthogonal collocation, Computers & Chemical Engineering, vol.8, issue.3-4, pp.243-248, 1984. ,
DOI : 10.1016/0098-1354(84)87012-X
Efficient Solution of Dynamic Optimization and NMPC Problems, Nonlinear Predictive Control Progress in Systems Theory, pp.219-244, 2000. ,
DOI : 10.1007/978-3-0348-8407-5_13
Introduction to Model Based Optimization of Chemical Processes on Moving Horizons, Online Optimization of Large Scale Systems: State of the Art, pp.295-340, 2001. ,
DOI : 10.1007/978-3-662-04331-8_18
1. Constrained Optimal Feedback Control of Systems Governed by Large Differential Algebraic Equations, Real-Time and Online PDE-Constrained Optimization. SIAM, 2006. ,
DOI : 10.1137/1.9780898718935.ch1
URL : https://hal.archives-ouvertes.fr/cea-01135394
A multiple shooting algorithm for direct solution of optimal control problems, Proceedings 9th IFAC World Congress Budapest, pp.243-247, 1984. ,
Applied Optimal Control, 1975. ,
Large-scale DAE optimization using a simultaneous NLP formulation, AIChE Journal, vol.13, issue.5, pp.1038-1050, 1998. ,
DOI : 10.1002/aic.690440505
A Quasi-Infinite Horizon Nonlinear Model Predictive Control Scheme with Guaranteed Stability??????This paper was not presented at any IFAC meeting. This paper was accepted for publication in revised form by Associate Editor W. Bequette under the direction of Editor Prof. S. Skogestad., Automatica, vol.34, issue.10, pp.1205-1218, 1998. ,
DOI : 10.1016/S0005-1098(98)00073-9
A kinematic notation for lower-pair mechanisms based on matrices Real-Time Optimization for Large Scale Nonlinear Pro- cesses, ASME Journal of Applied Mechanics, vol.22, pp.215-221, 1659. ,
Real-Time Optimization for Large Scale Nonlinear Processes, volume 920 of Fortschr.-Ber, Steuerungs-und Regelungstechnik . VDI Verlag, 1659. ,
A Real-Time Iteration Scheme for Nonlinear Optimization in Optimal Feedback Control, SIAM Journal on Control and Optimization, vol.43, issue.5, pp.1714-1736, 2005. ,
DOI : 10.1137/S0363012902400713
Real-time optimization and nonlinear model predictive control of processes governed by differential-algebraic equations, Journal of Process Control, vol.12, issue.4, pp.577-585, 2002. ,
DOI : 10.1016/S0959-1524(01)00023-3
2. A Stabilizing Real-Time Implementation of Nonlinear Model Predictive Control, Real-Time and Online PDE-Constrained Optimization. SIAM, 2004. ,
DOI : 10.1137/1.9780898718935.ch2
URL : https://hal.archives-ouvertes.fr/jpa-00209207
Nominal stability of real-time iteration scheme for nonlinear model predictive control, IEE Proceedings - Control Theory and Applications, vol.152, issue.3, pp.296-308, 2005. ,
DOI : 10.1049/ip-cta:20040008
An efficient algorithm for nonlinear model predictive control of large-scale systems. Part II: Application to a distillation column, Automatisierungstechnik, issue.1, pp.5122-5151, 2003. ,
Optimization of multiple-fraction batch distillation with recycled waste cuts, AIChE Journal, vol.53, issue.12, pp.482869-2874, 2002. ,
DOI : 10.1002/aic.690481214
Efficient NMPC of unstable periodic systems using approximate infinite horizon closed loop costing, Annual Reviews in Control, vol.28, issue.1, pp.37-45, 2004. ,
DOI : 10.1016/j.arcontrol.2004.01.011
Robot dynamics: equations and algorithms, Proceedings 2000 ICRA. Millennium Conference. IEEE International Conference on Robotics and Automation. Symposia Proceedings (Cat. No.00CH37065), 2000. ,
DOI : 10.1109/ROBOT.2000.844153
URL : http://axiom.anu.edu.au/~roy/papers/icra00.pdf
Fast nonlinear model predictive control of gasoline engines, CCA Conference Munich, 2006. ,
Computation and performance assesment of nonlinear model predictive control, Proc. 42th IEEE Conf. Decision Contr, pp.4613-4618, 2002. ,
SYMORO+: A system for the symbolic modelling of robots, Robotica, vol.15, issue.2, pp.153-161, 1997. ,
DOI : 10.1017/S0263574797000180
URL : https://hal.archives-ouvertes.fr/hal-00401687
On Converting Optimal Control Problems into Nonlinear Programming Problems, Computational Mathematical Programming , volume F15 of NATO ASI, pp.261-280, 1985. ,
DOI : 10.1007/978-3-642-82450-0_9
Efficient reduced SQP methods for the optimization of chemical processes described by large sparse DAE models, 1999. ,
An efficient multiple shooting based reduced SQP strategy for large-scale dynamic process optimization, Computers & Chemical Engineering, vol.27, issue.2, pp.167-174, 2003. ,
DOI : 10.1016/S0098-1354(02)00195-3
Generalized Solutions of Hamilton-Jacobi Equations, 1982. ,
A stabilizing model-based predictive control algorithm for nonlinear systems, Automatica, vol.37, issue.9, pp.1351-1362, 2001. ,
DOI : 10.1016/S0005-1098(01)00083-8
Nonlinear model predictive control: Challenges and opportunities, Nonlinear Predictive Control Progress in Systems Theory, pp.23-44, 2000. ,
Receding horizon control of nonlinear systems, IEEE Transactions on Automatic Control, vol.35, issue.7, pp.814-824, 1990. ,
DOI : 10.1109/9.57020
Stability and Robustness of Nonlinear Receding Horizon Control, Nonlinear Predictive Control of Progress in Systems Theory, pp.3-23, 2000. ,
Numerical Optimization, 1999. ,
DOI : 10.1007/b98874
Review of nonlinear model predictive control applications, Nonlinear model predictive control: theory and application, pp.3-32, 2001. ,
Multivariable Predictive Control of Nonlinear Chemical Processes, 2000. ,
Online implementation of nonlinear MPC: An experimental case study, AD- CHEM2000 -International Symposium on Advanced Control of Chemical Processes, pp.731-736, 2000. ,
The development of an efficient optimal control package, Proceedings of the 8th IFIP Conference on Optimization Techniques, 1977. ,
DOI : 10.1007/BFb0006520
Fast reduced multiple shooting methods for nonlinear model predictive control, Chemical Engineering and Processing: Process Intensification, vol.46, issue.11, 2006. ,
DOI : 10.1016/j.cep.2006.06.024
Reduced SQP methods for large-scale optimal control problems in DAE with application to path planning problems for satellite mounted robots, 1996. ,
Solving discretized optimization problems by partially reduced SQP methods, Computing and Visualization in Science, vol.1, issue.2, pp.83-96, 1998. ,
DOI : 10.1007/s007910050008
Optimal Dynamic Motion Planning for Underactuated Robots, 2000. ,
Numerical solution of optimal control problems by direct collocation In Optimal Control: Calculus of Variations, Optimal Control Theory and Numerical Methods, 1993. ,
Nonlinear Model Predictive Control via Feasibility-Perturbed Sequential Quadratic Programming, Computational Optimization and Applications, vol.28, issue.1, pp.87-121, 2004. ,
DOI : 10.1023/B:COAP.0000018880.63497.eb
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.8.8835
Predictive powertrain control for heavy duty trucks, Proceedings of IFAC Symposium in Advances in Automotive Control 53. A. Toumi. Optimaler Betrieb und Regelung von Simulated Moving Bed Prozessen, pp.451-457, 2004. ,
Optimal control of multibody systems in minimal coordinates, Zeitschrift fur Angewandte Mathematik und Mechanik 78, 1998. ,
Modélisation et Commande d'un Robot Marcheur Anthropomorphe, 2000. ,
Some comments on the structure of the dynamics of articulated motion, Proceedings of the Ruperto Carola Symposium on Fast Motion in Biomechanics and Robotics, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00390428
Nonlinear Model Predictive Control of Robots Using Real-time Optimization, AIAA/AAS Astrodynamics Specialist Conference and Exhibit, 2004. ,
DOI : 10.2514/6.2004-5295
