On-line Reference Trajectory Definition with Joint Torque and Velocity Constraints, The International Journal of Robotics Research, vol.11, issue.1, 1992. ,
DOI : 10.1177/027836499201100106
A sensitivity approach to optimal spline robot trajectories, Automatica, 1991. ,
Dynamic Scaling of Manipulator Trajectories, Journal of Dynamic Systems, Measurement, and Control, vol.106, issue.1, 1984. ,
DOI : 10.1115/1.3149652
Time-Optimal Control of Robotic Manipulators Along Specified Paths, The International Journal of Robotics Research, vol.1, issue.3, 1985. ,
DOI : 10.1177/027836498500400301
Formulation and optimization of cubic polynomial joint trajectories for industrial robots, IEEE Transactions on Automatic Control, vol.28, issue.12, 1983. ,
DOI : 10.1109/TAC.1983.1103181
Displaying method for duty of industrial robot, 1995. ,
Motor controller, 2001. ,
Applied Optimal Control: Optimization, Estimation, and Control, IEEE Transactions on Systems, Man, and Cybernetics, vol.9, issue.6, 1975. ,
DOI : 10.1109/TSMC.1979.4310229
Optimal Control and the calculus of Variations, 1993. ,
Modélisation, identification et commande des robots, 1999. ,
Survey of Numerical Methods for Trajectory Optimization, Journal of Guidance, Control, and Dynamics, vol.21, issue.2, 1997. ,
DOI : 10.2514/2.4231
Formulation of Joint Trajectories for Industrial Robots Using B-Splines, IEEE Transactions on Industrial Electronics, vol.34, issue.2, 1987. ,
DOI : 10.1109/TIE.1987.350954
Numerical Optimization : Theoritical and Practical Aspects, 2003. ,
DOI : 10.1007/978-3-662-05078-1
Comparison of automatic and symbolic differentiation in mathematical modeling and computer simulation of rigid-body systems On time optimal path control of manipulators with bounded joint velocities and torques, 18] L. ? Zlajpah Proceedings IEEE Int. Conf. on Robotics and Automation, 1996. ,
User's guide for cfsqp version 2.5: A C-code for solving (large scale) constrained nonlinear (minimax) optimization problems, generating iterates satisfying all inequality constraints, 1997. ,
