Time-Optimal Control of Robotic Manipulators Along Specified Paths, The International Journal of Robotics Research, vol.1, issue.3, 1985. ,
DOI : 10.1177/027836498500400301
On-line Reference Trajectory Definition with Joint Torque and Velocity Constraints, The International Journal of Robotics Research, vol.11, issue.1, 1992. ,
DOI : 10.1177/027836499201100106
Numerical Optimization : Theoritical and Practical Aspects, 2003. ,
DOI : 10.1007/978-3-662-05078-1
Applied Optimal Control: Optimization, Estimation, and Control, IEEE Transactions on Systems, Man, and Cybernetics, vol.9, issue.6, 1975. ,
DOI : 10.1109/TSMC.1979.4310229
A survey of robot programming systems, Proceedings of the Australasian Conference on Robotics and Automation in, 2003. ,
Recent progress in unconstrained nonlinear optimization without derivatives, Mathematical Programming, vol.12, issue.1, 1997. ,
DOI : 10.1007/BF02614326
Displaying method for duty of industrial robot. Japan Patent JP7087787, 1995. ,
Practical Methods of Optimization, Second Edition, 1987. ,
Dynamic Scaling of Manipulator Trajectories, Journal of Dynamic Systems, Measurement, and Control, vol.106, issue.1, 1984. ,
DOI : 10.1115/1.3149652
Learning control of robot manipulators ASME Journal of Dynamic Systems Measurement and Control 50th Anniversary Issue, KD99] Wisama Khalil and Etienne Dombre. Modélisation, identification et commande des robots, 1993. ,
Method for foreseeing working limit of teaching playback type robot, 1988. ,
Formulation and optimization of cubic polynomial joint trajectories for industrial robots, IEEE Transactions on Automatic Control, vol.28, issue.12, 1983. ,
DOI : 10.1109/TAC.1983.1103181
A sensitivity approach to optimal spline robot trajectories, Automatica, 1991. ,
Iterative learning control and repetitive control for engineering practice, International Journal of Control, vol.73, issue.10, pp.930-954, 2000. ,
DOI : 10.1080/002071700405905
User's guide for cfsqp version 2.5 : A c code for solving (large scale) constrained nonlinear (minimax) optimization problems, generating iterates satisfying all inequality constraints, 1997. ,
Controller for industrial robot Japan Patent JP1020990, Pin93] Enid Pinch. Optimal Control and the calculus of Variations, 1989. ,
An efficient method for finding the minimum of a function of several variables without calculating derivatives, The Computer Journal, vol.7, issue.2, 1964. ,
DOI : 10.1093/comjnl/7.2.155
Direct search algorithms for optimization calculations, Acta Numerica, vol.8, 1998. ,
DOI : 10.1007/BF00933295
The NEWUOA software for unconstrained optimization without derivatives, 40th Workshop on Large Scale Nonlinear Optimization, 2004. ,
DOI : 10.1007/0-387-30065-1_16
Function Minimization by Interpolation in a Data Table, IMA Journal of Applied Mathematics, vol.12, issue.3, 1973. ,
DOI : 10.1093/imamat/12.3.339
Statistique : Economie, Gestion, Sciences, Médecine. Economica, 1990. [ ? Zla96] L. ? Zlajpah. On time optimal path control of manipulators with bounded joint velocities and torques, Proceedings IEEE Int. Conf. on Robotics and Automation, 1996. ,
