On the Implementation of Model Predictive Control for On-line Walking Pattern Generation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This article addresses the real-time implementation issues of a model predictive control based walking pattern generation for a humanoid robot. We approximate the multibody dynamic model with a linear discrete time system, and at each step solve a quadratic program in order to keep the output within a predefined set of constraints. The focus is on creating an efficient framework for forming and solving the underlying optimization problem. For that purpose we develop: a) a reliable guess for the active constraints at optimality; b) a fast way of generating an initial feasible point with respect to the set of constraints for each preview interval; c) a variable discretization sampling time. A simple implementation of a standard primal active set algorithm which exploits a "hot start" is used to demonstrate the advantages of the first point, while the latter one is verified using an existing dual solver.
Dimitrov2008ICRA.pdf (280.75 Ko) Télécharger le fichier
inria-00390492 , version 1 (02-06-2009)
Dimitar Dimitrov, Pierre-Brice Wieber, Joachim Ferreau, Moritz Diehl. On the Implementation of Model Predictive Control for On-line Walking Pattern Generation. ICRA 2008 - IEEE International Conference on Robotics & Automation, May 2008, Pasadena, CA, United States. pp.2685-2690, ⟨10.1109/ROBOT.2008.4543617⟩. ⟨inria-00390492⟩
258 Consultations
587 Téléchargements
