Optimal Byzantine Resilient Convergence in Asynchronous Robot Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
We propose the first deterministic algorithm that tolerates up to $f$ byzantine faults in $3f+1$-sized networks and performs in the asynchronous CORDA model. Our solution matches the previously established lower bound for the semi-synchronous ATOM model on the number of tolerated Byzantine robots. Our algorithm works under bounded scheduling assumptions for oblivious robots moving in a uni-dimensional space.
convergence.pdf (193.06 Ko) Télécharger le fichier
inria-00390870 , version 1 (02-06-2009)
  • HAL Id : inria-00390870 , version 1
  • ARXIV : 0906.0651
Zohir Bouzid, Maria Potop-Butucaru, Sébastien Tixeuil. Optimal Byzantine Resilient Convergence in Asynchronous Robot Networks. [Research Report] ???. 2009, pp.15. ⟨inria-00390870⟩
244 Consultations
67 Téléchargements
