A posteriori error covariances in variational data assimilation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Russian Journal of Numerical Analysis and Mathematical Modelling Année : 2009
The problem of variational data assimilation for a nonlinear evolution model is formulated as an optimal control problem to find some unknown parameters of the model. The equation for the error of the optimal solution is derived through the statistical errors of the input data (background, observation, and model errors). A numerical algorithm is developed to construct an a posteriori covariance operator of the analysis error using the Hessian of an auxiliary optimal control problem based on the tangent linear model constraints.
inria-00391869 , version 1 (05-06-2009)
Victor P. Shutyaev, François-Xavier Le Dimet, Igor Gejadze. A posteriori error covariances in variational data assimilation. Russian Journal of Numerical Analysis and Mathematical Modelling, 2009, 24 (2), pp.161-169. ⟨10.1515/RJNAMM.2009.011⟩. ⟨inria-00391869⟩
81 Consultations
0 Téléchargements
