HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Preprints, Working Papers, ...
On the Decidability of (ground) Reachability Problems for Cryptographic Protocols (extended version)
Yannick Chevalier 1 Mounira Kourjieh 2
1 CASSIS - Combination of approaches to the security of infinite states systems
FEMTO-ST - Franche-Comté Électronique Mécanique, Thermique et Optique - Sciences et Technologies (UMR 6174), Inria Nancy - Grand Est, LORIA - FM - Department of Formal Methods
Abstract : Analysis of cryptographic protocols in a symbolic model is relative to a deduction system that models the possible actions of an attacker regarding an execution of this protocol. We present in this paper a transformation algorithm for such deduction systems provided the equational theory has the finite variant property. the termination of this transformation entails the decidability of the ground reachability problems. We prove that it is necessary to add one other condition to obtain the decidability of non-ground problems, and provide one new such criterion.
Complete list of metadata
Cited literature [31 references]  Display  Hide  Download
https://hal.inria.fr/inria-00392226
Contributor : Yannick Chevalier Connect in order to contact the contributor
Submitted on : Friday, June 5, 2009 - 6:03:20 PM
Last modification on : Friday, January 21, 2022 - 3:08:59 AM
Long-term archiving on: : Thursday, June 10, 2010 - 10:16:24 PM
tech-repp.pdf
Identifiers
  • HAL Id : inria-00392226, version 1
  • ARXIV : 0906.1199
Citation
Yannick Chevalier, Mounira Kourjieh. On the Decidability of (ground) Reachability Problems for Cryptographic Protocols (extended version). 2008. ⟨inria-00392226⟩
Share
Metrics
Record views
179
Files downloads
82
