A multilayer Saint-Venant model: Derivation and numerical validation, Discrete and Continuous Dynamical Systems - Series B, vol.5, issue.2, pp.189-214, 2005. ,
DOI : 10.3934/dcdsb.2005.5.189
Mathematical Justification of the Hydrostatic Approximation in the Primitive Equations of Geophysical Fluid Dynamics, SIAM Journal on Mathematical Analysis, vol.33, issue.4, pp.847-859, 2001. ,
DOI : 10.1137/S0036141000375962
´ Etude et parallélisation d'un code d'´ eléments finis pour la modélisation quasigéostrophique des circulations océaniques, 1990. ,
Dynamique de l'atmosphère et de l'océan, chapter 5, pp.115-118, 2001. ,
Validity of the Quasigeostrophic Model for Large-Scale Flow in the Atmosphere and Ocean, SIAM Journal on Mathematical Analysis, vol.25, issue.4, pp.1023-1068, 1994. ,
DOI : 10.1137/S0036141092234980
Existence of Global Weak Solutions for a 2D Viscous Shallow Water Equations and Convergence to the Quasi-Geostrophic Model, Communications in Mathematical Physics, vol.238, issue.1, pp.211-223, 2003. ,
DOI : 10.1007/s00220-003-0859-8
Analyse fonctionnelle, théorie et applications, 2000. ,
An external-internal mode coupling for a 3d hydrodynamical model for applications at regional scale (mars) Advances in Water Resources, 2007. ,
Derivation of viscous Saint-Venant system for laminar shallow water; numerical validation. Discrete and Continuous Dynamical Systems-series B, pp.89-102, 2001. ,
URL : https://hal.archives-ouvertes.fr/hal-00691701
Athmosphere-Ocean Dynamics, 1982. ,
Ekman layers of rotating fluids, the case of well prepared initial data, Communications in Partial Differential Equations, vol.104, issue.11, pp.953-975, 1997. ,
DOI : 10.1080/03605309708821290
A shallow water model with eddy viscosity for basins with varying bottom topography, Nonlinearity, vol.14, issue.6, pp.1493-1515, 2001. ,
DOI : 10.1088/0951-7715/14/6/305
Effet cosinus sur un mod??le visqueux de type Saint-Venant et ses ??quations limites de type quasi-g??ostrophique et lacs, Comptes Rendus Mathematique, vol.345, issue.6, pp.313-318, 2007. ,
DOI : 10.1016/j.crma.2007.07.013
URL : https://hal.inria.fr/inria-00176131/document
NEMO reference manual, ocean dynamics component : NEMO-OPA, Note du Pole de modélisation, Institut Pierre-Simon Laplace (IPSL), 2008. ,
Theoretical and numerical study of shallow water models ; applications to nearshore hydrodynamics. Phd, 2005. ,
Ekman layers of rotating fluids: The case of general initial data, Communications on Pure and Applied Mathematics, vol.15, issue.4, pp.432-483, 2000. ,
DOI : 10.1002/(SICI)1097-0312(200004)53:4<432::AID-CPA2>3.0.CO;2-Y
Geophysical fluid dynamics, 1987. ,
DOI : 10.1007/978-1-4612-4650-3
A comparison of two numerical methods for integrating a quasi geostrophic multilayer model of ocean circulations, J. Comp. Phys, vol.110, pp.341-359, 1994. ,
Boundary Value Problems for the Inviscid Primitive Equations in Limited Domains, 2008. ,
DOI : 10.1016/S1570-8659(08)00211-1
Théorie du mouvement non-permanent des eaux, avec application aux crues desrivì eres etàet`età l'introduction des marées dans leur lit, Comptes Rendus de l'Académie des Sciences, pp.147-154, 1871. ,
On the order of magnitude of the baroclinic flow in the primitive equations of the ocean, Annali di Matematica Pura ed Applicata, vol.82, issue.S5, pp.185-293, 2006. ,
DOI : 10.1007/s10231-004-0146-0
URL : https://hal.archives-ouvertes.fr/hal-00014259
Fast elliptic solvers on rectangular parallelepipeds ,
