A new class of semi-parametric estimators of the second order parameter, Portugaliae Mathematica, vol.60, pp.193-214, 2003. ,
Estimation of the parameter controlling the speed of convergence in extreme value theory, Mathematical Methods of Statistics, vol.12, pp.155-176, 2003. ,
Regression with response distributions of Pareto-type, Computational Statistics & Data Analysis, vol.42, issue.4, pp.595-619, 2003. ,
DOI : 10.1016/S0167-9473(02)00120-2
Asymptotic normality of convergent estimates of conditional quantiles, Statistics, vol.1, issue.2, pp.139-169, 2001. ,
DOI : 10.1214/aos/1176348513
Retrieval of Mars surface physical properties from OMEGA hyperspectral images using regularized sliced inverse regression, Journal of Geophysical Research, vol.20, issue.2, p.6005, 2009. ,
DOI : 10.1029/2008JE003171
URL : https://hal.archives-ouvertes.fr/inria-00276116
Gaussian Regularized Sliced Inverse Regression, Statistics and Computing, vol.5, issue.22, pp.85-98, 2009. ,
DOI : 10.1007/s11222-008-9073-z
URL : https://hal.archives-ouvertes.fr/inria-00180458
Regular Variation, 1987. ,
DOI : 10.1017/CBO9780511721434
Generalized additive modelling of sample extremes, Journal of the Royal Statistical Society: Series C (Applied Statistics), vol.51, issue.1, pp.207-222, 2005. ,
DOI : 10.1016/0304-4076(82)90100-2
Estimation non paramétrique de la régression par la méthode du noyau, 1976. ,
Local likelihood smoothing of sample extremes, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.62, issue.1, pp.191-208, 2000. ,
DOI : 10.1111/1467-9868.00228
Models for exceedances over high thresholds, Journal of the Royal Statistical Society, series B, vol.52, pp.393-442, 1990. ,
On the Estimation of the Extreme-Value Index and Large Quantile Estimation, The Annals of Statistics, vol.17, issue.4, pp.1795-1832, 1989. ,
DOI : 10.1214/aos/1176347396
Modelling extremal events, 1997. ,
DOI : 10.1007/978-3-642-33483-2
Nonparametric modelling for functional data, 2005. ,
Estimation non paramétrique de la médiane conditionnelle, médianogramme et méthode du noyau, Publications de l'Institut de Statistique de l, pp.11-22, 1990. ,
Reference curves based on non-parametric quantile regression, Statistics in Medicine, vol.VIII, issue.20, pp.3119-3135, 2002. ,
DOI : 10.1002/sim.1226
Estimating the support of a Poisson process via the Faber-Shauder basis and extreme values. Publications de l'Institut de Statistique de l, pp.43-72, 2002. ,
A moving window approach for nonparametric estimation of the conditional tail index, Journal of Multivariate Analysis, vol.99, issue.10, pp.2368-2388, 2008. ,
DOI : 10.1016/j.jmva.2008.02.023
URL : https://hal.archives-ouvertes.fr/inria-00124637
Conditional extremes from heavy-tailed distributions: an application to the estimation of extreme rainfall return levels, Extremes, vol.73, issue.2, pp.177-204, 2010. ,
DOI : 10.1007/s10687-010-0100-z
URL : https://hal.archives-ouvertes.fr/hal-00371757
Functional nonparametric estimation of conditional extreme quantiles, Journal of Multivariate Analysis, vol.101, issue.2, pp.419-433, 2010. ,
DOI : 10.1016/j.jmva.2009.06.007
URL : https://hal.archives-ouvertes.fr/hal-00289996
Sur unprobì eme d'estimation géométrique. Publications de l'Institut de Statistique de l, pp.191-210, 1964. ,
Estimation of a support curve via order statistics, Extremes, vol.3, issue.3, pp.251-277, 2000. ,
DOI : 10.1023/A:1011407111136
Extreme values and kernel estimates of point processes boundaries, ESAIM: Probability and Statistics, vol.8, pp.150-168, 2004. ,
DOI : 10.1051/ps:2004008
Frontier estimation via kernel regression on high power-transformed data, Journal of Multivariate Analysis, vol.99, issue.3, pp.403-420, 2008. ,
DOI : 10.1016/j.jmva.2006.11.006
URL : https://hal.archives-ouvertes.fr/hal-00077683
Central limit theorems for smoothed extreme value estimates of point processes boundaries, Journal of Statistical Planning and Inference, vol.135, issue.2, pp.433-460, 2005. ,
DOI : 10.1016/j.jspi.2003.08.005
URL : https://hal.archives-ouvertes.fr/hal-00383141
Semi-parametric estimation of the second order parameter, asymptotic and finite sample behaviour, Extremes, vol.3, issue.3, pp.207-229, 2000. ,
DOI : 10.1023/A:1011470010228
Extreme Value Theory: An Introduction, Series in Operations Research and Financial Engineering, 2006. ,
DOI : 10.1007/0-387-34471-3
Nonparametric analysis of temporal trend when fitting parametric models to extreme-value data, Statistical Science, vol.15, pp.153-167, 2000. ,
On the Estimation of a Support Curve of Indeterminate Sharpness, Journal of Multivariate Analysis, vol.62, issue.2, pp.204-232, 1997. ,
DOI : 10.1006/jmva.1997.1681
Estimation of Non-sharp Support Boundaries, Journal of Multivariate Analysis, vol.55, issue.2, pp.205-218, 1995. ,
DOI : 10.1006/jmva.1995.1075
A Simple General Approach to Inference About the Tail of a Distribution, The Annals of Statistics, vol.3, issue.5, pp.1163-1174, 1975. ,
DOI : 10.1214/aos/1176343247
Minimax theory of image reconstruction, Lecture Notes in Statistics, vol.82, 1993. ,
DOI : 10.1007/978-1-4612-2712-0
Quantile regression analysis of hedge fund strategies, Journal of Empirical Finance, vol.16, issue.2, pp.264-279, 2009. ,
DOI : 10.1016/j.jempfin.2008.10.002
Multidimensional limit theorems for smoothed extreme value estimates of point processes boundaries, ESAIM: Probability and Statistics, vol.12, pp.273-307, 2008. ,
DOI : 10.1051/ps:2007039
Statistical inference using extreme order statistics. The Annals of Statistics, pp.119-131, 1975. ,
Nonparametric Estimation of the Transition Distribution Function of a Markov Process, The Annals of Mathematical Statistics, vol.40, issue.4, pp.1386-1400, 1969. ,
DOI : 10.1214/aoms/1177697510
Non-parametric estimation of conditional quantiles, Statistics & Probability Letters, vol.7, issue.5, pp.407-412, 1989. ,
DOI : 10.1016/0167-7152(89)90095-3
Extreme Value Analysis of Environmental Time Series: An Application to Trend Detection in Ground-Level Ozone, Statistical Science, vol.4, issue.4, pp.367-393, 1989. ,
DOI : 10.1214/ss/1177012400
Consistent nonparametric regression (with discussion) The Annals of Statistics, pp.595-645, 1977. ,
Conditional empirical processes. The Annals of Statistics, pp.638-647, 1986. ,
Estimation of parameters and large quantiles based on the k largest observations, Journal of the American Statistical Association, vol.73, pp.812-815, 1978. ,
Conditional predictive regions for stochastic processes, 1999. ,
