The DMM bound: multivariate (aggregate) separation bounds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we derive aggregate separation bounds, named after Davenport-Mahler-Mignotte (\dmm), on the isolated roots of polynomial systems, specifically on the minimum distance between any two such roots. The bounds exploit the structure of the system and the height of the sparse (or toric) resultant by means of mixed volume, as well as recent advances on aggregate root bounds for univariate polynomials, and are applicable to arbitrary positive dimensional systems. We improve upon Canny's gap theorem \cite{c-crmp-87} by a factor of $\OO(d^{n-1})$, where $d$ bounds the degree of the polynomials, and $n$ is the number of variables. One application is to the bitsize of the eigenvalues and eigenvectors of an integer matrix, which also yields a new proof that the problem is polynomial. We also compare against recent lower bounds on the absolute value of the root coordinates by Brownawell and Yap \cite{by-issac-2009}, obtained under the hypothesis there is a 0-dimensional projection. Our bounds are in general comparable, but exploit sparseness; they are also tighter when bounding the value of a positive polynomial over the simplex. For this problem, we also improve upon the bounds in \cite{bsr-arxix-2009,jp-arxiv-2009}. Our analysis provides a precise asymptotic upper bound on the number of steps that subdivision-based algorithms perform in order to isolate all real roots of a polynomial system. This leads to the first complexity bound of Milne's algorithm \cite{Miln92} in 2D.
emt-dmm-issac-10.pdf (260.43 Ko) Télécharger le fichier
inria-00393833 , version 1 (09-06-2009)
inria-00393833 , version 2 (09-06-2009)
inria-00393833 , version 3 (12-05-2010)
inria-00393833 , version 4 (10-06-2010)
  • HAL Id : inria-00393833 , version 3
  • ARXIV : 1005.5610
Ioannis Z. Emiris, Bernard Mourrain, Elias Tsigaridas. The DMM bound: multivariate (aggregate) separation bounds. International Symposium on Symbolic and Algebraic Computation (ISSAC), Jul 2010, Munich, Germany. ⟨inria-00393833v3⟩
335 Consultations
332 Téléchargements
