An IP Next Generation Compliant Java ™ Virtual Machine - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
This paper discusses the implementation of an \emph{IPv6.java.net} package allowing distributed applications to benefit from all the new aspects of the IPv6 protocol such as: security, flow control, mobility and multicast. Moreover, we present a full IP Next Generation Compliant \emph{Java Virtual Machine}, that is a JVM which is able to handle both IPv4 and IPv6 protocols from standard Java APIs and in a totally transparently way for the user/programmer.
Mots clés
inria-00099199 , version 1 (26-09-2006)
Guillaume Chelius, Eric Fleury. An IP Next Generation Compliant Java ™ Virtual Machine. IPDPS 2000 - International Workshop on Java for Parallel & Distributed Computing, D. Caromel, S. Chaumette, G. Fox, P. Graham, May 2000, Cancun, Mexico. pp.528-535, ⟨10.1007/3-540-45591-4_72⟩. ⟨inria-00099199⟩
163 Consultations
0 Téléchargements
