New interface
Reports (Research report)
NEPI: Using Independent Simulators, Emulators, and Testbeds for Easy Experimentation
Mathieu Lacage 1 Martin Ferrari 1 Mads Hansen 1 Thierry Turletti 1 Walid Dabbous 1
1 PLANETE - Protocols and applications for the Internet
Inria Grenoble - Rhône-Alpes, CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : The evaluation of new network protocols, applications, and architectures, requires the use of many kinds of experimentation environments: simulators, emulators, testbeds, and sometimes, combinations of these. As the functionality and complexity of these tools increases, mastering and efficiently using each of them is becoming increasingly difficult. In this paper, we consider how to make it easier to use multiple tools separately and together to improve the productivity of network researchers. We show how a single object model which encompasses every aspect of a typical experimentation workflow can be used to completely describe experiments to be run within very different experimentation environments. Although Nepi is still in early prototyping stage, we expect that its ability to describe and automate easily complex mixed experiments will enable further experimentation with heterogenous networks.
Document type :
Complete list of metadata
Cited literature [3 references]  Display  Hide  Download
https://hal.inria.fr/inria-00397692
Contributor : Mathieu Lacage Connect in order to contact the contributor
Submitted on : Tuesday, June 23, 2009 - 8:40:39 AM
Last modification on : Wednesday, October 26, 2022 - 8:16:23 AM
Long-term archiving on: : Monday, October 15, 2012 - 2:41:16 PM
File
RR-6967.pdf
Identifiers
  • HAL Id : inria-00397692, version 1
Collections
Citation
Mathieu Lacage, Martin Ferrari, Mads Hansen, Thierry Turletti, Walid Dabbous. NEPI: Using Independent Simulators, Emulators, and Testbeds for Easy Experimentation. [Research Report] RR-6967, INRIA. 2009. ⟨inria-00397692⟩
Share
Metrics
Record views
96
Files downloads
96
