D. Aldous and J. M. Steele, Asymptotics for euclidean minimal spanning trees on random points. Probab. Thery Relat, pp.247-258, 1992.
S. Asmussen, P. Fiorini, L. Lipsky, T. Rolski, and R. Sheahan, Asymptotic Behavior of Total Times for Jobs That Must Start Over if a Failure Occurs, Mathematics of Operations Research, vol.33, issue.4, pp.932-944, 2008.
DOI : 10.1287/moor.1080.0329
M. Audrey, A. J. Viterbi, and . Viterbi, Erlang capacity of a power controlled CDMA system, IEEE Journal on Selected Areas in Communications, vol.8, issue.116, pp.892-899, 1993.
F. Baccelli and B. Blaszczyszyn, A New Phase Transitions for Local Delays in MANETs, 2010 Proceedings IEEE INFOCOM, 2010.
DOI : 10.1109/INFCOM.2010.5462132
URL : https://hal.archives-ouvertes.fr/hal-00940551
F. Baccelli, B. B?aszczyszyn, and M. Karray, Up- and Downlink Admission/Congestion Control and Maximal Load in Large Homogeneous CDMA Networks, Mobile Networks and Applications, vol.9, issue.6, pp.605-617, 2004.
DOI : 10.1023/B:MONE.0000042499.64488.ba
URL : https://hal.archives-ouvertes.fr/inria-00071625
F. Baccelli, B. B?aszczyszyn, and M. Karray, Blocking rates in large CDMA networks via a spatial erlang formula, Proceedings IEEE 24th Annual Joint Conference of the IEEE Computer and Communications Societies., pp.94-95, 2005.
DOI : 10.1109/INFCOM.2005.1497879
URL : https://hal.archives-ouvertes.fr/inria-00070489
F. Baccelli, B. B?aszczyszyn, and M. Karray, A spatial markov qeueing process and its applications to wireless loss systems, INRIA, p.94, 2007.
F. Baccelli, B. B?aszczyszyn, and O. Mirsadeghi, Optimal paths on the space-time SINR random graphs. submitted for publication, p.163, 2009.
F. Baccelli, B. Blaszczyszyn, and P. Mühlethaler, An Aloha protocol for multihop mobile wireless networks, Proceedings of the Allerton Conference, pp.421-436, 2003.
DOI : 10.1109/TIT.2005.862098
F. Baccelli, B. Blaszczyszyn, and P. Mühlethaler, A stochastic model for spatial and opportunistic aloha. JSAC. Special Issue on Stochastic Geometry and Random Graphs for Wireless Networks, p.99, 2009.
F. Baccelli, B. Blaszczyszyn, and P. Mühlethaler, Time-Space Opportunistic Routing in Wireless Ad hoc Networks: Algorithms and Performance Optimization by Stochastic Geometry, The Computer Journal, vol.53, issue.5, p.163, 2009.
DOI : 10.1093/comjnl/bxp049
URL : https://hal.archives-ouvertes.fr/hal-00940564
F. Baccelli, B. B?aszczyszyn, and F. Tournois, Downlink capacity and admission/congestion control in CDMA networks, Proc. of IEEE INFOCOM, p.100, 2003.
URL : https://hal.archives-ouvertes.fr/inria-00466279
F. Baccelli and C. Bordenave, The radial spanning tree of a Poisson point process, The Annals of Applied Probability, vol.17, issue.1, pp.305-359, 2007.
DOI : 10.1214/105051606000000826
URL : https://hal.archives-ouvertes.fr/inria-00070309
P. Billingsley, Probability and Measure, p.174, 1995.
S. Biswas and R. Morris, Exor: opportunistic multi-hop routing for wireless networks, Proceedings of SIGCOMM '05, pp.133-144, 2005.
B. B?aszczyszyn and M. Karray, An efficient analytical method for dimensioning of CDMA cellular networks serving streaming calls, Proceedings of the 3rd International Conference on Performance Evaluation Methodologies and Tools, p.100, 2008.
DOI : 10.4108/ICST.VALUETOOLS2008.4258
B. B?aszczyszyn and M. Karray, Dimensioning of the downlink in OFDMA cellular networks via an Erlang's loss model, 2009 European Wireless Conference, p.100, 2009.
DOI : 10.1109/EW.2009.5358006
B. B?aszczyszyn and M. K. Karray, Performance Evaluation of Scalable Congestion Control Schemes for Elastic Traffic in Cellular Networks with Power Control, IEEE INFOCOM 2007, 26th IEEE International Conference on Computer Communications, p.100, 2007.
DOI : 10.1109/INFCOM.2007.28
B. B?aszczyszyn and M. K. Karray, An efficient analytical method for dimensioning of CDMA cellular networks serving streaming calls, Proceedings of the 3rd International Conference on Performance Evaluation Methodologies and Tools, p.100, 2008.
B. B?aszczyszyn and P. Mühlethaler, Stochastic Analysis of Non-Slotted Aloha in Wireless Ad-Hoc Networks, 2010 Proceedings IEEE INFOCOM, p.99, 2010.
DOI : 10.1109/INFCOM.2010.5462086
B. B?aszczyszyn, P. Mühlethaler, and Y. Toor, Maximizing throughput of linear vehicular Ad-hoc NETworks (VANETs) ??? a stochastic approach, 2009 European Wireless Conference, p.99, 2009.
DOI : 10.1109/EW.2009.5358011
B. B?aszczyszyn and B. Radunovi´cradunovi´c, M/D/1/1 loss system with interference and applications to transmit-only sensor networks, 2007 5th International Symposium on Modeling and Optimization in Mobile, Ad Hoc and Wireless Networks and Workshops, p.27, 2007.
DOI : 10.1109/WIOPT.2007.4480073
B. B?aszczyszyn and B. Radunovi´cradunovi´c, Using Transmit-Only Sensors to Reduce Deployment Cost of Wireless Sensor Networks, IEEE INFOCOM 2008, The 27th Conference on Computer Communications, p.27, 2008.
DOI : 10.1109/INFOCOM.2008.176
B. Blum, T. He, S. Son, and J. Stankovic, Igf: A state-free robust communication protocol for wireless sensor networks, p.163, 2003.
C. Bordenave, Navigation on a Poisson point process, The Annals of Applied Probability, vol.18, issue.2, p.163, 2006.
DOI : 10.1214/07-AAP472
URL : https://hal.archives-ouvertes.fr/inria-00070231
P. Brémaud, Mathematical Principles of Signal Processing, p.180, 2002.
DOI : 10.1007/978-1-4757-3669-4
E. W. Dijkstra, A note on two problems in connexion with graphs, Numerische Mathematik, vol.4, issue.1, pp.269-271, 1959.
DOI : 10.1007/BF01386390
M. Durvy, O. Dousse, and P. Thiran, Self-Organization Properties of CSMA/CA Systems and Their Consequences on Fairness, IEEE Transactions on Information Theory, vol.55, issue.3, p.78, 2009.
DOI : 10.1109/TIT.2008.2011427
N. Ehsan and R. L. Cruz, On the Optimal SINR in Random Access Networks with Spatial Reuse, 2006 40th Annual Conference on Information Sciences and Systems, p.99, 2006.
DOI : 10.1109/CISS.2006.286601
J. Evans and D. Everitt, On the teletraffic capacity of CDMA cellular networks, IEEE Transactions on Vehicular Technology, vol.48, issue.1, p.100, 1999.
DOI : 10.1109/25.740079
W. Feller, An Introduction to Probability Theory and its Applications, volume II, 1971.
R. K. Ganti and M. Haenggi, Bounds on the information propagation delay in interference-limited ALOHA networks, 2009 7th International Symposium on Modeling and Optimization in Mobile, Ad Hoc, and Wireless Networks, p.163, 2009.
DOI : 10.1109/WIOPT.2009.5291569
R. K. Ganti and H. M. , Spatial and temporal correlation of the interference in ALOHA ad hoc networks, IEEE Communications Letters, vol.13, issue.9, 2009.
DOI : 10.1109/LCOMM.2009.090837
E. N. Gilbert and E. N. Gilbert, Random plane networks Random subdivisions of space into crystals. The Annals of Mathematical Statistics 33-3 On routing in random rayleigh fading networks, SIAM J. IEEE Transactions on Wireless Communications, vol.9, issue.4, pp.533-543, 1961.
M. Haenggi, Outage, local throughput, and capacity of random wireless networks, IEEE Transactions on Wireless Communications, vol.8, issue.8, 2009.
DOI : 10.1109/TWC.2009.090105
M. Haenggi, J. Andrews, F. Baccelli, and O. , Stochastic Geometry and Random Graphs for Wireless Networks. Special Issue of IEEE JSAC Congestion measures in DS-CDMA networks, IEEE Trans. on Comm, vol.47, issue.3, p.197, 1999.
C. D. Howard and C. M. Newman, Euclidean models of first-passage percolation. Probab. Theory Relat, pp.153-170, 1997.
A. Hunter, J. Andrews, and S. Weber, Capacity scaling of ad hoc networks with spatial diversity. submitted for publication, p.99, 2008.
P. Jacquet, Realistic wireless network model with explicit capacity evaluation. submitted for publication, p.99, 2008.
URL : https://hal.archives-ouvertes.fr/inria-00203339
P. Jacquet, B. Mans, P. Mühlethaler, and G. Rodolakis, Opportunistic routing in wireless ad hoc networks: Upper bounds for the packet propagation speed, 2008 5th IEEE International Conference on Mobile Ad Hoc and Sensor Systems, pp.1192-1202, 2009.
DOI : 10.1109/MAHSS.2008.4660054
V. Jarník, About a certain minimal problem, Práce Moravské P?írodov?decké Spole?nosti, vol.6, pp.57-63, 0197.
P. Jelenkovi´cjelenkovi´c and J. Tan, Can retransmissions of superexponential documents cause subexponential delays?, Proc. of INFOCOM, p.164, 2007.
P. Jelenkovi´cjelenkovi´c and J. Tan, Is aloha causing power law delays?, Managing Traffic Performance in Converged Networks, p.164, 2007.
N. Jindal, J. Andrews, and S. Weber, Fractional power control for decentralized wireless networks, IEEE Transactions on Wireless Communications, vol.7, issue.12, pp.5482-5492, 2008.
DOI : 10.1109/T-WC.2008.071439
N. Jindal, S. Weber, and J. Andrews, Bandwidth partitioning in decentralized wireless networks, IEEE Transactions on Wireless Communications, vol.7, issue.12, pp.5408-5419, 2008.
DOI : 10.1109/T-WC.2008.071220
B. Karp, Geographic routing for wireless networks, p.163, 2000.
B. Karp and H. T. Kung, GPSR, Proceedings of the 6th annual international conference on Mobile computing and networking , MobiCom '00, pp.243-254, 2000.
DOI : 10.1145/345910.345953
M. K. Karray, Analytic evaluation of wireless cellular networks performance by a spatial Markov process accounting for their geometry, dynamics and control schemes, p.100, 2007.
B. Kauffmann, F. Baccelli, F. Chaintreau, V. Mhatre, K. Papagiannaki et al., Measurementbased self organization of interfering 802.11 wireless access networks, Proceedings of IEEE IN- FOCOM'07, pp.1451-1459, 2007.
J. M. Keil and C. Gutwin, Classes of graphs which approximate the complete euclidean graph, Discrete & Computational Geometry, vol.11, issue.1, pp.13-28, 1992.
DOI : 10.1007/BF02187821
F. P. Kelly, Loss Networks, The Annals of Applied Probability, vol.1, issue.3, pp.319-378, 1991.
DOI : 10.1214/aoap/1177005872
S. Keshav, An Engineering Approach to Computer Networking, p.197, 1997.
J. Kingman, Subadditive Ergodic Theory, The Annals of Probability, vol.1, issue.6, pp.883-899, 1973.
DOI : 10.1214/aop/1176996798
URL : http://projecteuclid.org/download/pdf_1/euclid.aop/1176996798
B. Kitchens, Symbolic Dynamics, p.81, 1998.
DOI : 10.1007/978-3-642-58822-8
L. Kleinrock, Queueing Systems, p.93, 1975.
Z. Liu and M. Zarki, Sir-based call admission control for DS-CDMA cellular systems, Selected Areas in Communications IEEE Journal on, vol.12, pp.638-644, 1994.
S. Meyn and R. Tweedie, Markov Chains and Stochastic Stability, p.128, 1993.
J. Møller, Lectures on Random Voronoi Tessellations, Lecture Notes in Statistics, vol.87, p.118, 1994.
DOI : 10.1007/978-1-4612-2652-9
H. Nguyen, F. Baccelli, and D. Kofman, A Stochastic Geometry Analysis of Dense IEEE 802.11 Networks, IEEE INFOCOM 2007, 26th IEEE International Conference on Computer Communications, pp.1199-1207, 2007.
DOI : 10.1109/INFCOM.2007.143
L. Pimentel, The time constant and critical probabilities in percolation models, Electronic Communications in Probability, vol.11, issue.0, pp.160-168, 2006.
DOI : 10.1214/ECP.v11-1210
R. C. Prim, Shortest Connection Networks And Some Generalizations, Bell System Technical Journal, vol.36, issue.6, pp.1389-1401, 1957.
DOI : 10.1002/j.1538-7305.1957.tb01515.x
L. Russo, A note on percolation, Zeitschrift f???r Wahrscheinlichkeitstheorie und Verwandte Gebiete, vol.51, issue.1, pp.39-48, 1987.
DOI : 10.1007/BF00535274
R. Serfozo, Introduction to stochastic networks, p.95, 1999.
DOI : 10.1007/978-1-4612-1482-3
M. Sidi and D. Starobinski, New call blocking versus handoff blocking in cellular networks, Proceedings of IEEE INFOCOM '96. Conference on Computer Communications, p.100, 1997.
DOI : 10.1109/INFCOM.1996.497875
I. Stojmenovic and X. Lin, Loop-free hybrid single-path/flooding routing algorithms with guaranteed delivery for wireless networks, IEEE Transactions on Parallel and Distributed Systems, vol.12, issue.10, pp.1023-1032, 2001.
DOI : 10.1109/71.963415
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.459.2008
I. Stojmenovic and X. Lin, Power-aware localized routing in wireless networks, IEEE Transactions on Parallel and Distributed Systems, vol.12, issue.11, pp.1122-1133, 2001.
DOI : 10.1109/71.969123
G. L. Stuber, Principles of Mobile Communication, Boston: Kluwer AP, p.177, 2001.
H. Takagi and L. Kleinrock, Optimal Transmission Ranges for Randomly Distributed Packet Radio Terminals, IEEE Transactions on Communications, vol.32, issue.3, pp.246-257, 1984.
DOI : 10.1109/TCOM.1984.1096061
D. Tse and P. Viswanath, Foundamentals of Wireless Communication, p.197, 2005.
M. Q. Vahidi-asl and J. C. Wierman, First-passage percolation on the Voronoi tessellation and Delaunay trangulation, Random Graphs'87; Based on Proceedings of the 3rd International Seminar on Random Graphs and Probabilistic Methods in Combinatorics, pp.341-359, 1990.
J. Venkataraman and M. Haenggi, Optimizing the throughput in random wireless ad hoc networks, Proceedings of the 42st Annual Allerton Conference on Communication, Control, and Computing, p.99, 2004.
S. Weber, J. Andrews, and N. Jindal, The Effect of Fading, Channel Inversion, and Threshold Scheduling on <emphasis>Ad Hoc</emphasis> Networks, IEEE Transactions on Information Theory, vol.53, issue.11, pp.4127-4149, 2007.
DOI : 10.1109/TIT.2007.907482
S. Weber, N. Jindal, R. K. Ganti, and M. Haenggi, Longest Edge Routing on the Spatial Aloha Graph, IEEE GLOBECOM 2008, 2008 IEEE Global Telecommunications Conference, p.163, 2008.
DOI : 10.1109/GLOCOM.2008.ECP.51
