Journal articles
Synchronous and Asynchronous Evaluation of Dynamic Neural Fields
Nicolas P. Rougier 1 Axel Hutt 1
1 CORTEX - Neuromimetic intelligence
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : In \cite{rougier:2006}, we've introduced a dynamic model of visual attention based on the Continuum Neural Field Theory \cite{Taylor:1999} that explained attention as being an emergent property of a dynamic neural field. The fundamental property of the model is its facility to select a single stimulus out of several perfectly identical input stimuli by applying asynchronous computation. In the absence of external noise and with a zero initial state, the theoretical mathematical solution of the field equation predicts the final equilibrium state to equally represent all of the input stimuli. This finding is valid for synchronous numerical computation of the system dynamics where elements of the spatial field are computed all together at each time point. However, asynchronous computation, where elements of the spatial field are iterated in time one after the other yields different results leading the field to move towards a single stable input pattern. This behavior is in fact quite similar to the effect of noise on dynamic fields. The present work aims at studying this phenomenom in some details and characterizes the relation between noise, synchronous evaluation (the ``regular'' mathematical integration) and asynchronous evaluation in the case of a simple dual particle system. More generally, we aim at explaining the behavior of a general differential equation system when it is considered as a set of particles that may or may not iterated by synchronous computations.
Complete list of metadata
Cited literature [21 references]  Display  Hide  Download
https://hal.inria.fr/inria-00403107
Contributor : Nicolas P. Rougier Connect in order to contact the contributor
Submitted on : Thursday, July 9, 2009 - 12:06:06 PM
Last modification on : Friday, February 4, 2022 - 3:19:44 AM
Long-term archiving on: : Monday, October 15, 2012 - 3:10:50 PM
File
RougierHuttRevised.pdf
Identifiers
Collections
Citation
Nicolas P. Rougier, Axel Hutt. Synchronous and Asynchronous Evaluation of Dynamic Neural Fields. Journal of Difference Equations and Applications, Taylor & Francis, 2010, In press, In press (In press), ⟨10.1080/10236190903051575⟩. ⟨inria-00403107⟩
Share
Metrics
Record views
146
Files downloads
221
