The Static Single Information Form, 1999. ,
Modern Compiler Implementation in Java, 2002. ,
DOI : 10.1017/CBO9780511811432
Register allocation and spill complexity under SSA, 2005. ,
Register Allocation: What does the NP-Completeness Proof of Chaitin et al. Really Prove?, The 19th International Workshop on Languages and Compilers for Parallel Computing (LCPC'06), 2006. ,
Optimal register sharing for high-level synthesis of SSA form programs, IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, vol.25, issue.5, pp.772-779, 2006. ,
DOI : 10.1109/TCAD.2006.870409
Interference graphs for procedures in static single information form are interval graphs, Proceedingsof the 10th international workshop on Software & compilers for embedded systems , SCOPES '07, pp.101-110, 2007. ,
DOI : 10.1145/1269843.1269858
Automatic construction of sparse data flow evaluation graphs, Proceedings of the 18th ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '91, pp.55-66, 1991. ,
DOI : 10.1145/99583.99594
Engineering a Compiler, 2004. ,
Efficiently computing static single assignment form and the control dependence graph, ACM Transactions on Programming Languages and Systems, vol.13, issue.4, pp.451-490, 1991. ,
DOI : 10.1145/115372.115320
Algorithmic Graph Theory and Perfect Graphs, Annals of Discrete Mathematics, vol.57, 2004. ,
Register Allocation for Programs in SSA-Form, Compiler Construction, 2006. ,
DOI : 10.1007/11688839_20
Nesting of reducible and irreducible loops, ACM Transactions on Programming Languages and Systems, vol.19, issue.4, pp.557-567, 1997. ,
DOI : 10.1145/262004.262005
The program structure tree, ACM SIGPLAN Notices, vol.29, issue.6, pp.171-185, 1994. ,
DOI : 10.1145/773473.178258
Register Allocation Via Coloring of Chordal Graphs, Proceedings of APLAS'05, pp.315-329, 2005. ,
DOI : 10.1007/11575467_21
On loops, dominators, and dominance frontiers, ACM Transactions on Programming Languages and Systems, vol.24, issue.5, pp.455-490, 2002. ,
DOI : 10.1145/570886.570887
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.13.202
Static Program Analysis Based on Virtual Register Renaming, 2006. ,
Identifying loops using DJ graphs, ACM Transactions on Programming Languages and Systems, vol.18, issue.6, pp.649-658, 1996. ,
DOI : 10.1145/236114.236115
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.42.3972
Sequentializing program dependence graphs for irreducible programs, 1993. ,
The maximum k-colorable subgraph problem for chordal graphs, Information Processing Letters, vol.24, issue.2, pp.133-137, 1987. ,
DOI : 10.1016/0020-0190(87)90107-4
