BPSK bit error outage over Nakagami-m fading channels in lognormal shadowing environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Communications Letters Année : 2007
In this letter, we address the problem of finding a tractable expression for the bit-error outage (BEO) defined as the probability to observe a given average bit error rate (BER) over a fading channel in a shadowing environment. Our contribution is two-fold: (1) a simple yet tight approximation of the bit error probability (BEP) for binary phase shift keying (BPSK) over a frequency-flat Nakagami-m fading channel is derived, which (2) facilitates the derivation of a tight lower bound of the BEO in presence of lognormal shadowing in closed form. Theoretical results are corroborated by means of simulation results, confirming the tightness of the bounds.
Fichier non déposé
inria-00404807 , version 1 (17-07-2009)
Philippe Mary, Mischa Dohler, Jean-Marie Gorce, Guillaume Villemaud, Maryline Arndt. BPSK bit error outage over Nakagami-m fading channels in lognormal shadowing environments. IEEE Communications Letters, 2007, 11 (7), pp.565-567. ⟨10.1109/LCOMM.2007.070241⟩. ⟨inria-00404807⟩
293 Consultations
0 Téléchargements
