Control and embedded computing: Survey of research directions, Proceedings of the 16th IFAC World Congress on Automatic Control, pp.342-353, 2005. ,
Decentralized control of satellite clusters under limited communication, Proceedings of the AIAA Guidance, Navigation, and Control Conference and Exhibit, pp.134-145, 2004. ,
Control of systems integrating logic, dynamics, and constraints, Automatica, vol.35, issue.3, pp.407-427, 1999. ,
DOI : 10.1016/S0005-1098(98)00178-2
Trading quantization precision for sampling rates in networked systems with limited communication, Proceedings of the 45th IEEE Conference on Decision an Control, pp.1135-1140, 2006. ,
Optimal integrated control and scheduling of systems with communication constraints, Proceedings of the Joint 44th IEEE Conference on Decision and Control and European Control Conference, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00466829
Optimal integrated control and scheduling of networked control systems with communication constraints: application to a car suspension system, IEEE Transactions on Control Systems Technology, vol.14, issue.4, pp.776-787, 2006. ,
DOI : 10.1109/TCST.2006.872504
Optimal scheduling of control tasks with state feedback resource allocation, Proceedings of the 2006 American Control Conference, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00364947
Distributed MEMS: new challenges for computation, IEEE Computational Science and Engineering, vol.4, issue.1, pp.12-16, 1997. ,
DOI : 10.1109/99.590851
Set invariance in control, Automatica, vol.35, issue.11, pp.1747-1767, 1999. ,
DOI : 10.1016/S0005-1098(99)00113-2
Quantized feedback stabilization of linear systems, IEEE Transactions on Automatic Control, vol.45, issue.7, pp.1279-1289, 2000. ,
DOI : 10.1109/9.867021
Stabilization of motor networks, Proceedings of 1995 34th IEEE Conference on Decision and Control, pp.1484-1488, 1995. ,
DOI : 10.1109/CDC.1995.480312
Minimum attention control, Proceedings of the 36th IEEE Conference on Decision and Control, 1997. ,
DOI : 10.1109/CDC.1997.657776
Differential coding in networked controlled linear systems, 2006 American Control Conference, 2006. ,
DOI : 10.1109/ACC.2006.1657374
URL : https://hal.archives-ouvertes.fr/hal-00130509
Stabilizing a linear system with quantized state feedback, IEEE Transactions on Automatic Control, vol.35, issue.8, pp.916-924, 1990. ,
DOI : 10.1109/9.58500
Stabilization of linear systems with limited information, IEEE Transactions on Automatic Control, vol.46, issue.9, pp.1384-1400, 2001. ,
DOI : 10.1109/9.948466
Quantized Stabilization of Linear Systems: Complexity Versus Performance, IEEE Transactions on Automatic Control, vol.49, issue.9, pp.1534-1548, 2004. ,
DOI : 10.1109/TAC.2004.834111
Packet-based control: The <mml:math altimg="si6.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:msub><mml:mrow><mml:mi>H</mml:mi></mml:mrow><mml:mrow><mml:mn>2</mml:mn></mml:mrow></mml:msub></mml:math>-optimal solution, Automatica, vol.42, issue.1, pp.137-144, 2006. ,
DOI : 10.1016/j.automatica.2005.08.011
A Moving Horizon Approach to Networked Control System Design, IEEE Transactions on Automatic Control, vol.49, issue.9, pp.1562-1572, 2004. ,
DOI : 10.1109/TAC.2004.834132
On the effect of quantization on performance, Proceedings of the 2006 American Control Conference, pp.1364-1369, 2006. ,
A Survey of Recent Results in Networked Control Systems, Proceedings of the IEEE, vol.95, issue.1, 2007. ,
DOI : 10.1109/JPROC.2006.887288
Optimal control with limited communication, 1999. ,
Limited communication control. System and Control Letters, pp.193-205, 1999. ,
DOI : 10.1016/s0167-6911(99)00020-1
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.139.4422
Theory and computation of disturbance invariant sets for discrete-time linear systems, Mathematical Problems in Engineering, vol.4, issue.4, pp.317-367, 1998. ,
DOI : 10.1155/S1024123X98000866
Control system performance under dynamic quantization: the scalar case, 2004 43rd IEEE Conference on Decision and Control (CDC) (IEEE Cat. No.04CH37601), pp.1884-1888, 2004. ,
DOI : 10.1109/CDC.2004.1430322
LQR optimization of linear system switching, IEEE Transactions on Automatic Control, vol.47, issue.10, pp.471701-1705, 2002. ,
DOI : 10.1109/TAC.2002.803539
On the model-based control of networked systems, Automatica, vol.39, issue.10, pp.1562-1572, 2004. ,
DOI : 10.1016/S0005-1098(03)00186-9
Stabilization with data-rate-limited feedback: tightest attainable bounds, Systems & Control Letters, vol.41, issue.1, pp.49-56, 2000. ,
DOI : 10.1016/S0167-6911(00)00037-2
Foundations of Control and Estimation Over Lossy Networks, Proceedings of the IEEE, 2007. ,
DOI : 10.1109/JPROC.2006.887306
On collaborative optimization and communication for a team of autonomous underwater vehicles, Proceedings of Reglermöte, 2004. ,
Control Under Communication Constraints, IEEE Transactions on Automatic Control, vol.49, issue.7, pp.1056-1068, 2004. ,
DOI : 10.1109/TAC.2004.831187
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.320.4348
Invariant approximations of the minimal robust positively Invariant set, IEEE Transactions on Automatic Control, vol.50, issue.3, pp.406-410, 2005. ,
DOI : 10.1109/TAC.2005.843854
Control with delayed and limited information: a first look, Proceedings of the 41st IEEE Conference on Decision and Control, 2002., pp.1231-1236, 2003. ,
DOI : 10.1109/CDC.2002.1184682
Systems with finite communication bandwidth constraints. II. Stabilization with limited information feedback, IEEE Transactions on Automatic Control, vol.44, issue.5, pp.1049-1053, 1999. ,
DOI : 10.1109/9.763226
Stability of networked control systems, IEEE Control Systems Magazine, vol.21, issue.1, pp.84-99, 2001. ,
DOI : 10.1109/37.898794
