About the Self-Stabilization of a Virtual Topology for Self-Organization in Ad Hoc Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Ad hoc networks are spontaneous wireless networks without any wired infrastructure, composed of mobile terminals. We assume that nodes must collaborate to set up an efficient network, such a collaboration requiring a self-organization in the network. We proposed a virtual structure to organize the network: the backbone is a connected structure helping to optimize the control traffic flooding. Clusters form services area, hierarchizing the network, electing one leader per cluster. Since the ad hoc topology is volatile, the self-stabilization of the algorithms is vital. The algorithms for both the construction and the maintenance are analytically studied to prove the self-stabilization of the proposed self-organization. Thus, the virtual structure is efficient and very scalable, a local topology change impacting only locally the virtual structure. Finally , simulations investigate the behavior and the performances of the virtual structure.
2005_06_07-Sss2005.pdf (695.78 Ko) Télécharger le fichier
inria-00406106 , version 1 (12-05-2020)
  • HAL Id : inria-00406106 , version 1
Fabrice Theoleyre, Fabrice Valois. About the Self-Stabilization of a Virtual Topology for Self-Organization in Ad Hoc Networks. SSS 2005 - International Symposium on Self-Stabilizing Systems, Oct 2005, Barcelone, Spain. ⟨inria-00406106⟩
39 Consultations
23 Téléchargements
