Optimization methods for optimal transmitter locations in a mobile wireless system, IEEE Transactions on Vehicular Technology, vol.51, issue.6, pp.1316-1337, 2002. ,
DOI : 10.1109/TVT.2002.804844
An Application of a Multi-Objective Tabu Search Algorithm to a Bicriteria Flowshop Problem, Journal of Heuristics, vol.10, issue.5, pp.463-481, 2004. ,
DOI : 10.1023/B:HEUR.0000045320.79875.e3
On the wireless local area network design problem with performance guarantees, Computer Networks, vol.48, issue.6, pp.856-66, 2005. ,
DOI : 10.1016/j.comnet.2004.11.009
A TABOO SEARCH BASED APPROACH TO FIND THE PARETO OPTIMAL SET IN MULTIPLE OBJECTIVE OPTIMIZATION, Engineering Optimization, vol.48, issue.3, pp.731-748, 1999. ,
DOI : 10.1080/03052159908941394
Applying multiple objective tabu search to continuous optimization problems with a simple neighbourhood strategy, International Journal for Numerical Methods in Engineering, vol.23, issue.3, pp.406-424, 2006. ,
DOI : 10.1002/nme.1455
Multiobjective optimization: Principles and Case Studies, 2004. ,
DOI : 10.1007/978-3-662-08883-8
A multi-objective tabu search for a single-machine scheduling problem with sequence-dependent setup times, European Journal of Operational Research, vol.175, issue.1, pp.318-337, 2006. ,
DOI : 10.1016/j.ejor.2005.04.038
Multi-Objective Optimization using Evolutionary Algorithms, 2001. ,
A fast and elitist multiobjective genetic algorithm: NSGA-II, IEEE Transactions on Evolutionary Computation, vol.6, issue.2, pp.182-197, 2002. ,
DOI : 10.1109/4235.996017
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.17.7771
On predicting in-building WiFi coverage with a fast discrete approach, International Journal of Mobile Network Design and Innovation, vol.2, issue.1, pp.3-12, 2007. ,
DOI : 10.1504/IJMNDI.2007.013799
URL : https://hal.archives-ouvertes.fr/inria-00404857
An Overview of Evolutionary Algorithms in Multiobjective Optimization, Evolutionary Computation, vol.3, issue.1, pp.1-161063, 1995. ,
DOI : 10.1162/evco.1994.2.3.221
Multiobjective optimization and multiple constraint handling with evolutionary algorithms. I. A unified formulation, IEEE Transactions on Systems, Man, and Cybernetics - Part A: Systems and Humans, vol.28, issue.1, pp.26-37, 1998. ,
DOI : 10.1109/3468.650319
Tabu Search Based Procedure for Solving the, pp.0-1, 2000. ,
URL : https://hal.archives-ouvertes.fr/hal-00462046
The Two Objectives Case, Journal of Heuristics, vol.6, issue.3, pp.361-3831381, 2000. ,
Tabu search for multiobjective combinatorial optimization: TAMOCO, Control and Cybernetics, vol.29, issue.3, pp.799-818, 2000. ,
A tabu method to find the Pareto solutions of multiobjective optimal design problems in electromagnetics, IEEE Transactions on Magnetics, vol.38, issue.2, pp.1013-1016, 2002. ,
DOI : 10.1109/20.996260
The development of a multi-objective Tabu Search algorithm for continuous optimisation problems, European Journal of Operational Research, vol.185, issue.3, pp.1192-1212, 2008. ,
DOI : 10.1016/j.ejor.2006.06.048
Mono- and multiobjective formulations for the indoor wireless LAN planning problem, Computers & Operations Research, vol.35, issue.12, pp.3885-3901, 2008. ,
DOI : 10.1016/j.cor.2007.02.011
Multi-objective meta-heuristics: An overview of the current state-of-the-art, European Journal of Operational Research, vol.137, issue.1, pp.1-9, 2002. ,
DOI : 10.1016/S0377-2217(01)00123-0
Multi-objective tabu search using a multinomial probability mass function, European Journal of Operational Research, vol.169, issue.3, pp.918-931, 2006. ,
DOI : 10.1016/j.ejor.2004.08.026
Multicriteria Design Model for Cellular Network, Annals of Operations Research, vol.107, issue.1/4, pp.251-265, 2001. ,
DOI : 10.1023/A:1014963418451
Optimal location of transmitters for micro-cellular radio communication system design, IEEE Journal on Selected Areas in Communications, vol.14, issue.4, pp.662-73, 1996. ,
DOI : 10.1109/49.490417
Muiltiobjective Optimization Using Nondominated Sorting in Genetic Algorithms, Evolutionary Computation, vol.27, issue.3, pp.221-248, 1994. ,
